1 members (RLB),
81
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,162 Posts1,056,940 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 26 New Guy | | New Guy Joined: Sep 2001 Posts: 26 | On my 46 1 Ton Chevy panel there are no engine side splash pans, laying flat along the engine from the engine side over to the frame, probably about at the engine block/oil pan joint, but there are some small front sheet metal brackets on each side of the lower radiator that make me wonder if there once were splash pans, or whatever they are called. My '30 Chevy Sedan has them. This truck had a swap to a 235 many years ago, so pans maybe were lost. They would probably fit the 235, I'd guess, but maybe not. Were there pans, would they fit now, and where might I find some? Thanks!! Doug, Ohio [email protected]937-533-0621 | | | | | Joined: Nov 2000 Posts: 700 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 700 | Doug,
My '41 has one pan left. I'll take a pix tomorrow for you. It's not installed right now.
Don My 1941 in the Stovebolt Gallery My Photo AlbumBut I tried, didn't I? ... At least I did that. RP McMurphy The past belongs to the future...but only the present can preserve it. Besides the noble art of getting things done, there is a nobler art of leaving things undone. | | | | | Joined: Apr 2000 Posts: 179 Shop Shark | | Shop Shark Joined: Apr 2000 Posts: 179 | There was one on either side of my '41 1.5 ton when I pulled the engine last winter. I removed one and the other is still on the truck.
Joe McNeel
http://mcneelnet.com/~jmcneel/59.html
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Don, could you post that in your album, I'd like to take a look at it also. Tks Denny G
Denny G Sandwich, IL
| | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | My ’41 had them on both sides. Initially I thought they were 1 inch thick. When all of the grease, caked oil, and road gravel was removed they turned out to be about 16 ga. sheet metal. They were FUBAR being so bent and rotted away they went into the trash.
At the back the pans were mounted to brackets extending inward from the frame at the point where the bellhousing starts. (On the drivers side the clutch return spring also is attached to this bracket.) At the front there were holes directly in the front engine crossmamber. | | | | | Joined: Sep 2001 Posts: 26 New Guy | | New Guy Joined: Sep 2001 Posts: 26 | Too bad, probably a lot of them were pitched. I would still like to get one for each side.
My '46 1 Ton Panel has two little thin brackets in front, on the front engine cross member, on each side, maybe 3" in size, sort of triangular shaped, that now don't do anything, so I think these held the fronts of the pans. In the back are the brackets you mentioned, Kip's41.
Surely some hot rodder has these left in his discard pile.
So we are down to two questions:
Would they fit now that my truck has a 235 instead of the 216?
Where can I find some? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I believe my 48 6400 had a pair, I'll see if I can find them.
Anyone have pictures of good ones installed in an AD truck? I think mine are bent out of shape, but now sure how they are supposed to look.
Grigg | | | | | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | When I got my 46, it had both sides in place, and in real good shape.
If I recall correctly, the exhaust was routed up through the driver side pan. That might be the only problem you might have with the 235, (the exhaust routing).
I didn't put them back in place when I replaced the engine, and split the manifold.
They're sitting on a shelf in the garage. I believe all of the brackets are still attached to the truck.
Don't want to get into a gray area here, but I might be open to an offer, if you were to send one my way via a PM/e-mail. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | My coe has them but im not sure that helps... I can get a pic if it would???
Jeff | | | | | Joined: Jun 2007 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 101 | My 41 had both of them in useable condition even. | | | | | Joined: Nov 2000 Posts: 700 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 700 | Here are the pix of the engine splash pan and brackets LINK Don My 1941 in the Stovebolt Gallery My Photo AlbumBut I tried, didn't I? ... At least I did that. RP McMurphy The past belongs to the future...but only the present can preserve it. Besides the noble art of getting things done, there is a nobler art of leaving things undone. | | |
