1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 128 | I received my brake booster from Chevy Duty (actually came from Classic Performance Products) for my '65 C-10. When I go to line it up on the firewall, only one bolt hole matches up (the lower right). The lower left hole is too far to the right and lower to line up, and there aren't any holes for the top of the mount. I'm guessing that this isn't going to be a bolt in modification. I'm thinking it may be easier to make a mounting bracket with studs welded on both sides. Anybody else run into this?
Thanks.
Lee | | | | | Joined: Mar 2007 Posts: 20 Junior Member | | Junior Member Joined: Mar 2007 Posts: 20 | The one I installed on my 1963 c10 I had too drill two holes in the fire wall to mount the booster. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | LeeA:
When installing a factory power brake booster, you must drill one hole and it's location is dimpled on the firewall. I have converted several of my '64-'66 Chevy trucks to power brakes using the factory power brake booster and mounting wedge. I am not sure what drilling or modifications are required when utilizing a custom power brake booster.
In either case, there is some drilling of the firewall required. Good luck with your project.
Tony | | | | | Joined: Oct 2006 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 128 | At looking at CPP's website, it looks like I need their Firewall Mounting Plate. http://www.classicperform.com/Instructions/PDF/6072FP.pdf For $320 for the booster, you would think they would throw in the mounting plate... or at least recommend you buy one when you place the order for the booster. "Oh yeah, you might want to buy the adaptor plate if you intend on installing this thing". Lee | | | | | Joined: Oct 2006 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 128 | Called CCP... "no adaptor needed, you should be able to loosen the bolts in the booster bracket and make it fit". The part shown in the installation instructions doesn't exist in their computer or catalog. Screw it, I'll just make my own mounting plate using their instructions for a part that doesn't exist.
Lee | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | Lee, I just installed one on a 65 C-20 that I got from ABS. It fit just fine with the existing holes. The existing MC holes lined up and I removed 2 bolts on the firewall which also lined up. There has been a lot written about CPP, mostly they just push parts across the counter and if you have a problem they are not much help. That's a sad commentary when you pay that much for something. Fred
| | | | | Joined: Oct 2006 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 128 | Thanks, yeah this is just the first impression... I've got a whole front disc brake setup from them too. I wonder what other surprises I'm in for.
Lee | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | Lee, The whole premise of this aftermarket stuff is that it is supposed to be a bolt on otherwise we could go to Pick Your Part and get something and make it work. I don't have any problem making them squirm by stopping payment on the credit card. That usually gets their attention. I can't tell how many times I've taken something back to the Truck Shop that was in no way going to work and have them tell me that it's the first time they heard of the problem. Bull! Good luck with the conversion, I hope it works out. Fred
| | | | | Joined: Oct 2006 Posts: 166 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 166 | Lee... we had the same issue with ours (also from CPP). Instead of drilling holes we used the the 2 opposite holes. It was definitly a pain to line up. When we called we got the exact same answer you did.
I am still having probs with the back drums. They lock up if you step on the brakes too fast. One of these days we will get that bug worked out. The push rod seems to be too long because the pedal engages too far back.
The front disk kit that we got from them had no issues at all. Make sure you bench bleed it first. We didnt and it took forever to get all the air out..lol. Had to take it all off again and do it right.
Good luck. I dont know much but I hope I helped a little.
SUPPORT OUR TROOPS "Some people wonder all their lives if they've made a difference. The Marines don't have that problem." -- Ronald Reagan 1966 Fleetside SWB Webshots | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Originally posted by Lori66:
I am thinking a proportioning valve may be in order. here is a good article with a write up on proportioning valves: http://www.stoptech.com/tech_info/wp_proportioning_valves.shtml -W | | | | | Joined: Aug 2004 Posts: 45 Junior Member | | Junior Member Joined: Aug 2004 Posts: 45 | I'm in the process of installing a proportioning valve on my 66 and let me tell you that part is easy, bending new line and flaring is a pain in the rear. | | |
