| | | Forums66 Topics128,081 Posts1,056,319 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | I ordered aluminum running board step plates from Classic Parts (formerly Chevy Duty) and discovered, after one simple rainfall, that I wasted my money in more ways than one! A film of white oxidation formed all over the entire step plate that will not come off no matter what I try! But, even worse than that, when I removed the step plates (getting my truck ready for paint) I discovered what must have been the equivalent of a quarter-cup of white powder -- oxidation -- underneath the plates, eating away at the paint!!! See Here
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Alan,
That's a strange deal. I have a set, on my 46, that look just like yours. I haven't had that experience at all. | | | | | Joined: Jul 2006 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 187 | Wow  I was going to get a set of those for my 36', I'll wait until you get your stainless ones done. Good call Alan!
'36 Tall cab Chevy 1.5 ton, '36 Low cab Chevy 1.5 ton, '53 GMC 2 ton, '51 GMC 640 5 ton, '47 Dodge 2 ton, '42 GMC CCKW 353 6X6.
| | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | Wow !! Thanks Alan... I was looking at that same step plate for my 51 but there ain't no way I'm getting those now... Im thinking about getting my running boards sprayed with Line-x and almost "got those step plates" What do you think about Line-x ? Ive got a friend that works there and he's done some other project for me in the past "toolbox drawers, underneath the fenders of my 51, etc," Your advice on your projects on your 54 have helped me out alot Thanks Alan !! Todd Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Aluminum doesn't play well with other metals, & those obviously have no anodizing to prevent corrosion. Man what a mess | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You probably set up a battery reaction with the steel underneath the plates.
You can do several things:
Don't use conductive screws to attach it (or use bushings), and use a sheet of mylar between the metals to protect the paint.
Etch the aluminum oxide off with acid, polish, and then clearcoat the aluminum to keep it from oxidizing again
Or, have them anodized.
Aluminum oxide is very very hard and almost impossible to grind off with abrasives, you need to use chemical means.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Jed - I guess you got anodized aluminum?
Todd - Line-x is cool ... not my idea, but it's a good way to *use* your running boards and not mess 'em up.
4ontheFloor - LOL ... it's a whole lot easier to just NIX that garbage altogether!
I'm gonna be a whole lot happier with the stainless diamond plate anyway because I'm designing them myself, they'll match my rear bumper and the windless retainers/door jamb sills I'm designing, too -- wait'll you see my design!
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Alan, out of curiosity, do you drive your truck in the winter? Being in the northeast you would probably have all the bad stuff on the road, just like where I live! That would sure enhance the battery action. | | | | | Joined: Jun 2002 Posts: 179 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 179 | Wow! Sorry to read and see the problem with the step plates.
Will you be posting them in the "Freebie" section? LOL!
When I go cruisin' in the old truck....women smile, men weep and dogs beg for rides.
| | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | thats an odd deal, i wouldn't think just the alum. would do it though 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Same thing with mine. Oxidized and cannot be cleaned. The oxidization has spread to the running board at the edges of the plates. What you can do is put a thick nylon washer under each bolt hole. This should keep it off the running board. | | | | | Joined: Jun 2006 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 272 | Major Bummer Alan! I have had those step plates on my '48 for about 10 years now and they are beginning to go dull like yours. I didn't want to drill holes in my running boards so I stuck the plates on with construction adhesive, then I cut the heads off of stainless steel screws and glued them (just the heads) into the the hole recesses. I know, sounds funky but they look good and have stayed there perfectly fine and when I decide I don't want the plates anymore, there won't be any holes in the running board. I guess the adhesive has acted like a barrier to prevent the 'battery effect'. I sure would like to see your new stainless plates once you have them fabricated. Cheers, littlebuddie
1948 AD Pickup
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Looks just like the crud that builds up on the bead surface on aluminum wheels. If any of you have problems with tire that leak down on aluminum wheels, but there's no puncture and sealants don't work, that's the culprit right there. Sorry if I got off topic, bit seeing that corrosion just reminded me of that.
Bill Burmeister | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | truckernix - Yup. I drive her year round. I never knew about this battery action thing ... weird. Aluminum sucks; stainless steel rules. Niagara - LOL! I threw them directly into the garbage ... right where they belong! olblu49 - Do yourself a favor and check *underneath* yours! littlebuddie - Wow -- that was smart. I was wondering if there was a way to use adhesive but I thought I might wind up losing them on the highway or something. I'm having my custom step plates mounted with 1/4" stainless spacers between them and the running boards.
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Longbox, I have heard a lot about those problems with aluminum rims. What a pain that must be, leaking from the seal. Personally I likes the days when wheels were made from Steel and they weren't fashion pieces! | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I work in a shop that sells alot of tires, so I see this on a regular basis. And the sealants that they sell won't work on a bead leak. I see lots of tire that are ruined from being run on flat from people putting the sealer in thinking it'll seal the tire up, and it was the bead all along.
Bill Burmeister | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | SALT, my dad worked on seaplanes in he last real war. He had to do maintenance on the props every day something to the effect that aluminum deteriorates in salt water at the square root, 1,2,4,16. I assume they made sure everything else had a good protective coat.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | You threw them away??? Hell, aluminum is bring over a buck a pound!
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass. Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
| | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | I don't ever want to see them again. :mad: And, believe me, they cost way more than a buck a pound! Anyway ... here's a picture of my plans for my two-tone paint job -- the truck goes to paint the weekend of May 5th: Click Here And here's a picture of the template I made for the new step plates ... they'll match the "scoop" deign of the paint job: Click Here
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Alan I check under my plates at least once a year and there is no problem except at the edges. For what its worth I did put a lot of paste wax on the running boards under the spot where the plate sits. | | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | I'm planning on getting my running boards line-xed. I don't like the look of the step plates, but I don't want to be scratching the paint.
Alan: Those homemade step plates are pretty sweet looking. They'll look good on your truck. | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Originally posted by truckernix: Longbox, I have heard a lot about those problems with aluminum rims. What a pain that must be, leaking from the seal. Personally I likes the days when wheels were made from Steel and they weren't fashion pieces! I hadn't bought a new truck for awhile, then in 2002 I bought a Dakota,,, came only with aluminum wheels... I am with you. I would like steel. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Originally posted by Super55: I hadn't bought a new truck for awhile, then in 2002 I bought a Dakota,,, came only with aluminum wheels... I am with you. I would like steel. You can get generic steel rims at just about any tire store for just about any application. They're not fancy, but they get the job done. I bought one once so I could have a real spare on one of my Bonnevilles. | | | | | Joined: Nov 2006 Posts: 180 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 180 | hmmm, and I was planning on putting a set of those on my truck when finished. Guess I have some time to come up with a better plan.
1950 Chevy 3100 5 window "in progress" 1967 Chevelle 300
| | | | | Joined: Apr 2007 Posts: 146 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 146 | Geeze! Glad you discovered that B4 you had it all painted up all pretty! NM, I aint buying a pair either...I SCARED! My poor truck cant handle anymore rust....he may actually FALL apart one day! Needs no more rust assistance thats for sure!
Chey LOST1953 My favorite color is CHROME The ugliest trucks are driven by the prettiest girls  I dont suffer from insanity, I enjoy it! O Lord, WHY did I buy another "Thing"? (again??) ---- 1953 Chevy 3800 1-ton Gallery More photos at MSN ----
