5 members (55shaker, Greg_H, Joe H, Peggy M, 78buckshot), 168 guests, and 2 robots.
Topics128,162
Posts1,056,943
Members48,458
I am in the process of re-doing the windshield. Like most 46 trucks, the frame is pretty rusty along the bottom. The screws that hold the crank mounting points to the windshield frame broke off.
Anyone have any tips on how to get the windshield frame to slide apart to to remove the old glass?
I am trying not to destroy what I have left as a new frame is $350 or something like that...
Once I get it apart and restored, a pro will install new glass.
I would bust out the glass if you are going to replace it anyway. Then it won't be so tight and may be easier to get apart. Soak everything in Kroil.
Paint & Body Shop moderator
You don't have to bust out any glass if you try this tech tip . That's what I did and it works.
ya but busting out the glass is more fun
1949 Chevy 3600 Flatbed all orginal
1964 gmc 4000
1973 gmc 6000
2005 chevy duramax 4x4
1994 chevy 1500
Trucks are GM and Tractors are Orange
"I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton
Just like steppenwood says, I did it the same way using a drummel. Worked well
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
keep/save your glass. You can sell it for some good $ to those guys building the rat rods. Flat stock glass with a good patina & haze......great for those rat rods.
Tim Sheridan
1947 First Series Chevy 1/2-Ton
"Liberty Series" - "Art Deco" - Whatever you'd like to call it.
Thanks for the link Steppenwood, I had not seen that one before.
I'll let you know how it turns out.
As far as saving the glass goes, the rear and side glass is still in good shape. The rear has the patina and haze and will have to go to the rat rodders.
The fronts are shot.
