1 members (5 Window 9434),
68
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | I'm here for a second opinion. My jeep has a temp gauge that isn't working. There's a hollow steel or copper tube that comes out the back and goes into the block. I've been told that the tube is full of ether! Can this be true? Ever heard of a system like this?
"Happiness equals reality minus expectations" - Tom Magliozzi
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Yeah Jim, it's called a capillary tube. All the old "bolts" had 'em too. My '54 235 has one. I didn't know they were filled with ether though, I just thought they were hollow (?) | | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | So, what's the pressure gauge full of? Chrithmath? 1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Now that's funny right there!!  | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I didn't ask, or don't remember, but the guy who rebuilt my 37 guages filled mine with some kind of gas. Mike says that this is one of the most accurate guages there is but I know sometime they can be a pain to route and be careful not to bend it or brake the solder connection. They aren't as touchy as you think but be careful handling them. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Yup, it's ether! I made the mistake og breaking the tube on mine. Got a good whiff of it. Garage smelled like ether for a few hours afterwards.
Bill Burmeister | | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | Actually, your tube is NOT filled with ether, and that's the problem--it should be. I just had mine repaired and calibrated by a guy back east (Vermont I think). It cost around $100.00. If you need the contact you can email me and I'll get it to you. He also wrapped the capillary tube with a spiral wire to protect it in the future. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | I was curious about the dynamics of ether and why it is used. Searching around I found a DIY repair for these tubes in your own garage. It sounded very do-able too.
Stuart | | | | | Joined: Oct 2001 Posts: 578 'Bolter | | 'Bolter Joined: Oct 2001 Posts: 578 | hotshoe36, your comment made me blow coffee out my nose. Thanks!
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | Carter's has a guy that repairs them I think in the $60.00 range | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | atomarc, so where did you find the information on this repair?
~Jim
| | | | | Joined: Jul 2006 Posts: 183 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 183 | Originally posted by Jim Bow: hotshoe36, your comment made me blow coffee out my nose. Thanks! diet pepsi, here. Now gotta clean up the mess. Funny! | | | | | Joined: Sep 2006 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 47 | How cool is that!Had no idea one could "try this at home"..the Stovebolt continues to fascinate! | | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | :rolleyes: Pressure gauges are filled with a gooey marshmallow-peep center, to go with the ether in the temp gauges. Duh. (It's actually engine oil, but who's counting?) | | | | | Joined: Apr 2006 Posts: 236 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 236 | Hillarious Hotshoe36.
58 Fleetside, 235, "The Old Buckin' Bronco"
| | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | I think Ether is used because it boils at a low temp and creates pressure as a gas. This pressure is what deflects the needle. I had read an article, and the refilling seems do-able. Its the calibration that I couldn't figure out. That's why I sent mine out. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I know how delicate a capillary tube can be so I was very careful when I removed it and replaced mine following a valve job. When I was starting the square flare nut into the head I got a whiff of something that at first I hoped was antifreeze but alas I knew it was that distinctive odor of ether. Most young people today don't know what it smells like because we are so protected from all those chemicals that were common everyday items years ago. For us old timers when we were kids it was not unusual to be exposed to and use ether, chloroform, formaldehyde, carbon tetrachloride, lye, mercury, carbide, leaded gas, etc. These were common cleaning chemicals or things that were used to capture and preserve our bug collections or to experiment with. In fact between Walgreen’s and the hardware store you could buy almost any chemical that you wanted back then. I remember buying over the counter at Walgreen’s the fixings for making black powder, potassium nitrate a.k.a. salt peter, sulfur and charcoal. The temp gauge worked just fine before I pulled the head and now she’s a dead duck. So maybe I’ll try the fix your pointing me to Stu. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I will never forget the nurse putting that black rubber mask over my face and the smell of ether when I had my tonsils out in the fall of 51. Thank goodness for better methods of pain suppression.
~Jim
| | | | | Joined: Apr 2006 Posts: 236 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 236 | I'll never forget organic chem lab. Day after day of ether. Fell asleep a couple of times on the bus on the way home and it was only a 15 minute ride.  Our professor told us how they used to wash their hands in benzene until somebody noticed that the incidence of certain cancers was much higher in lab personel than the general populace and was able to trace it back to high levels of benzene in their bodies. What's really serious is how everything is labled as dangerous in labs now days; so, you stop taking any of the warning labels seriously. If I had known how low of a dose of carbon tet was carcinogenic and how low of a dose was lethel, I wouldn't have handled it without gloves. But, when even the D.I. water is labeled you tend to ignore the labels.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Big Chevy 3600, my Brother had his out the same way, on the kitchen table! I wasn't around yet to witness it, thank goodness! | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | If you arn't a strictly stock person it would be a lot cheaper to change over to electric. | | |
