2 members (78buckshot, NJC),
99
Mod | | | Forums66 Topics128,149 Posts1,056,819 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 101 Member | | Member Joined: Dec 2005 Posts: 101 | I am running a 350 in my 55. Latley I have had two spark plugs foul out when I realy floor it! The weird thing is that both times the electrode is curled over and touching the porcelain insulator in the plug. It first happened on #5 plug, then #6 plug. The plugs are Bosch/Platinum plugs and are 2 yrs old. Im wondering if my pistons are some how hitting my spark plugs. If so why now?
Roger
Roger http://www.flickr.com/photos/45469713@N00/?saved=1
| | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | Maybe carbon build up on pistons. Or REALLY loose rod bearings, but I think you would know the latter. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | I don't think the pistons could hit the plug, but I'll bet pre-ignition or severe detonation could knock them out of whack.
Stuart | | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | to clean the carbon off the pistons, i was told you can take a mixture on brake fiuld and water and pour down your carb. until the truck alomst dies, it will smoke, and stink to high heaven, but will remove carbon off the pistons. a friend of mine told me about this, said he had done it before, but i don't like the sound of it too much myself :confused:
but i would change plugs, put in some of the nice 3-4 prong plugs so if that helps, maybe get "shallower plugs" some that don't thread way way in 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Dec 2005 Posts: 101 Member | | Member Joined: Dec 2005 Posts: 101 | mikes 63-k10 that is my next step to get plugs with less threads on them............this just puzzles me why the truck is doing this now when I has ran fine for two yrs
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I would try some different plugs but shure wouldn,t put in plugs with shorter threads. They would cause more problems. You can get plugs without the extended tip. The tip is recessed in the shell. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | To me it sounds like a mechanical hit from a valve.
Tighten up the plug in the plug hole. Mark the plug so you can tell the direction of the tip when it is installed. It is probably lined up just right so the valve hits it.
Try another plug that lines up differently. | | | | | Joined: Nov 2001 Posts: 1,519 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,519 | Add another spark plug washer to the ones that are "fouling"? Just a thought. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I've sprayed water into the carb of a running engine before to knock out the carbon. We'd have it running at high idle and squirt water into the carb as fast as we could and try to keep the engine running. It would puke out all kinds of carbon out of the exhauast. Make sure you do it outside though.
A possible problem it could create is chunks of carbon getting stuck in the valves, so I wouldn't try it on a whim, but if you definitely know you have a haevy carbon problem...you don't have much to loose.
I would check out the indexing of the plug first. | | | | | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | Diesel it.Pour d in a hot engine slowley and keep the rpm's to keep it running for about 30 seconds.then pour enough so that engine stalls. Let set over night. Start next day and take for drive. Will be hard to start. Smoke great. | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Rogpatt, let us know what fixes your problem. I got a coke riding on the answer.
| | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | Builder i didn't know water worked to do that, and Beaver 53 the diesel won't mess up your engine/ carb? 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Dec 2005 Posts: 101 Member | | Member Joined: Dec 2005 Posts: 101 | Everyone I ask says something is hitting the plug. But it has happened on both sides of the engine so I am not sure whats going on now!
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | It's the valves making contact with the end of the plug. Try indexing them as I stated above. | | | | | Joined: Jun 2006 Posts: 20 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 20 | I'm w/ Builder's suggestion; seems like only a hit from a valve could bend the electrode to touch the porcelain. His indexing tip is the way to go to prove the theory w/ no pain & all gain. tomo | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | I looked at a cut-away of the SBC and It sure doesn't look like the valve could hit the plug unless it (the plug) was about a inch too long. Seems like the insulator would be the first fatality in a direct hit. Interesting problem! Stuart | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | It is interesting that the pistons of the two that failed are on the same crank throw. Have you worked on you carb and lost any parts? Things like nuts can pop back and forth between cylinders and then out the exhaust. How's your compression on #5 and #6 compare with the rest? | | | | | Joined: Dec 2005 Posts: 101 Member | | Member Joined: Dec 2005 Posts: 101 | I will be working on trying to figure out why my plugs are fouling out this weekend and get back to you guys on monday
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | And what are the final results Rogpatt? | | | | | Joined: Dec 2005 Posts: 101 Member | | Member Joined: Dec 2005 Posts: 101 | Sorry for the delay guys! I ran my compression tester on each cylinder and they were fine. So I then repalced my expensive bosch plugs with cheap auto lights, adjusted my timing and the problem has not occured aqain. I did not feel comfortable pouring water down my carb. I have ran the truck hard a couple of times and so far so good. Now can you guys look at my new post "Timing my Truck" and see if you can help me out there!
| | | | | Joined: Dec 2005 Posts: 101 Member | | Member Joined: Dec 2005 Posts: 101 | Look what I noticed when researching "Summit Racing Street & Strip Multi-Spark Digital CD Ignitions". I copied and pasted a portion of what was on the web site.
The capacitive discharge systems create the strongest spark possible at full voltage, with multiple sparks below 3,000 rpm to improve starting ability, idle quality, and throttle response, (((((while preventing plug fouling due to cylinder load-up))))))).
| | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | The bending of electodes is not considered "plug fouling", that is an entirely different thing. | | |
