4 members (Steelonsteel, klhansen, Gray_Ghost, Bill Hanlon), 54 guests, and 1 robot.
Topics128,076
Posts1,055,924
Members48,430
I am installing power steering on my '69 C-10 2wd
Got the gearbox no problem, got the pump, no problem, got the barckets-BIG PROBLEM. Alternator mounts on the left side, pump goes under it. I have 3 sets of brackets, nothing works. Motor is 307 with no bolt holes in the heads.Anyone have any ideas or pictures? Thanks
Junior Member
Junior Member
1 Offline
I think there is a bracket that mounts off the first hole of the exhaust manifold.you might have to make one.
If you have a short water pump you may have to change to the long one. My 71 C-30 hangs off a boss on the water pump. But that will cause you to have to change all your pulleys. You may want to visit some wrecking yards and see if you can find a complete drive system. buying pieces can get frustrating for sure get one that is complete. Hope you find a simple solution.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
I had to make a custom mount , that attaches to my exhaust manifolds .. I am runnin late 60's Rams horn manifolds on mine ..an on the drivers side i had 2 mounting holes in that manifold ...might need one like that ?
1952 Chevy Shortbed
Photos in Photobucket
sounds like you need a water pump mount like hevyhauler said
1949 Chevy 3600 Flatbed all orginal
1964 gmc 4000
1973 gmc 6000
2005 chevy duramax 4x4
1994 chevy 1500
Trucks are GM and Tractors are Orange
"I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton
Crusty Old Sarge
Crusty Old Sarge
The P/S pump on my 68' 327 mounted to the front of the block, 2 holes just above the oil pan next to the timing cover. The rear of the pump mounts to the first hole on the side motormount. A mount off of mid 60's engine should work well, you may have to do some digging in the wrecking yards to find one. Good luck!
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
To Tuts59
That is one of the set-ups I have but the pump sits way too far forward when I when put it on. Do you have "long or short" water pump? How many pulleys on the crank?
This shouldn't be this hard, I just feel like I'm missing something simple.
Thanks to everyone for the ideas, please keep them coming, I really want to get this right.
