6 members (Guitplayer, Jay R, dunfire, 78buckshot, Shade Baby, GrandpasJimmy), 81 guests, and 3 robots.
Topics128,186
Posts1,057,322
Members48,469
#228666 03/05/2007 12:24 AM
I went to a hot rod show and saw some cool cars today. I saw a truck with a super clean motor comartment. There didn't appear to be a big drum-type master cylinder with the resevoirs for the disc brakes. all you could see was firewall which looked very clean. It's the second time I've seen it like that on a late 50s chevy truck. How do they do that? I ask because I'd like to add front discs and keep that area clean like that. Or at least nothing bigger than the original master cylinder I have there now.
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
#228667 03/05/2007 12:55 AM
I do know that alot of rat rodders tuck stuff up under the dash. Did you take any pics?
58' 3200 235 3-speed/OD
#228668 03/05/2007 1:07 AM
I believe they mount the master cylinder and booster under the floor on the drivers side. I'm installing that under my 46. The power brake setup is a very expensive system but cleans up the firewall. You can even install an off-set type steering column which puts the firewall side of the column a lot lower and just about out of sight. Another expensive item. I think a clean firewall looks sharp and enhances the look of the engine compartment. Bob T
#228669 03/05/2007 1:08 AM
It is possible that the master cylinder is located in the original location. I am in the process of changingb to front discs on my 55 1st series and have the new dual chamber master cylinder in the stock location.
cgresham1212
If you don't drive it, why have it?
55 1st Series 3100 5 window
#228670 03/05/2007 3:19 AM
No pics this time. But it looked sort of like this http://rides.webshots.com/photo/2226076210071636143eFsLeX
My Webshot Photos]
#228671 03/05/2007 3:23 AM
Where do they run all the wires?
In the fenders?
#228673 03/05/2007 4:01 AM
CPP offers the under floor mount dual
master/booster in the stock location.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
#228674 03/05/2007 4:04 AM
my firewall is not as clean as the pic you posted but I do have my master cylinder under my floor board. I used an actual Stang II mastercyl with booster with it all under the driver side. A good friend made me a bracket that fastened to the side of the chassis and the master cyl/booster bolts right to it. He then made me a brake pedal. It all works very good. Colin ask where are the wires, well they can be run "up and Under". Under the firewall, up the kick panel etc. I ran most of mine up and under but I did like the little "thingy"/rubber gromet on the firewall of my 37 that a couple wires/cable goes through and kept it.
#228675 03/05/2007 4:19 PM
Quote
How can it be under the floor AND in the stock location :confused:
My Webshot Photos]
#228676 03/05/2007 5:18 PM
Quote
How can it be under the floor AND in the stock location :confused: [/QB]
It's under the floorboard on the older ones.
http://www.cardomain.com/ride/2412127/2
She's one 55 year old with a spare tire that looks good!
It's not rocket surgery. . . .
http://www.picturetrail.com/fredoly
#228677 03/06/2007 3:51 AM
Sorry BMD, I thought we were talking pre-60 trucks. I need to read closer.
1957 GMC 150
#228678 03/06/2007 4:36 AM
Hey jmoore, no apology needed, we were talking pre-60's. I've only seen this on the task force trucks. I was assuming they had the original master cylinder on the firewall like mine. Now it's all coming clear. I'm wondering if it's possible to do on a 60 - 62 like mine. Might not be safe?
My Webshot Photos]
