4 members (GusG, carbking, 2-Ton, 1 invisible), 89 guests, and 2 robots.
Topics128,196
Posts1,057,386
Members48,469
Has anyone done this AND kept the stock height, 6 lug pattern, and torsion bar IFS?
A couple of the usual vendors have the kits, but none with spindles for retaining stock height. One of them has everything I want except that their spindles give a 2 1/2" drop. I also need a kit with the provisions for the hydraulic clutch. I'm hoping someone out there has done this. Thanks
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
Here ya go
web page
Hope this helps ya
Current project . . . 1960 LB stepide Chevy
Hey halfpint, nice truck! I dig those hoods. Thanks for the link. That's the best bet I've got so far with what I've found. They say on that page that it may not work with factory drum wheels. My wheels were made by Stockton Wheel with original centers on new rims to allow for tie rod clearance AND accept good radial tires. They are still mounted on the same original factory drums. I'll have to check it out. Cheers!
My Webshot Photos]
Sorry I couldn't be more help to you.I'll look thru some of my catalogs and see if I can find something else.If I do I'll drop you a line.
Don't be sorry yet. It does say it MAY not work. I'm an optimist.
My Webshot Photos]
Z
Z Offline
www.mpbrakes.com has a combo brake/clutch setup for you.
eek I guess I'll have to get a third job. It's actually not bad and they include everything. Shouldn't skimp on the brakes anyway. Thanks Zenish
My Webshot Photos]
I hear ya bigmacdaddy.These 60-62 are diffenant money pits with all there 'SPECIAL"parts.I've thought about ditching the torsion bar frontend,but decided to keep it so it would be close to stock.
CPP has a kit you can keep the stock height. We just ordered and got mine (but we went with the drop). Give them a call. 800-522-5004.
SUPPORT OUR TROOPS
"Some people wonder all their lives if they've made a difference. The Marines don't have that problem." -- Ronald Reagan
1966 Fleetside SWB Webshots
Go to:
http://www.scarebird.com/
and talk to Mark, he's done conversion kits using a custom bracket and off the shelf parts for many applications. If he doesn't already have a bracket for your truck he might make a one for you. Good prices, nice product.
Quote
This is going to be a show-stopper on any disc brake conversion. The brake caliper will not clear the corner radius on the older wheels.
Fred
52 3600
69 C-10
