1 members (frogfarmer),
116
0
Mod | | | Forums66 Topics128,109 Posts1,056,268 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 18 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 18 | I've had a heck of time getting the king pins out of my 57 3100. Over the course of several weeks I tried various types of penetrant with no luck. The k-pins were stuck in the axle so hard that my punch/drift shattered or bent when I tried beating them out. I even tried a solid 3/4 inch steel bar which mushroomed on the end where I was beating it. Those pins did not want to come out and I did not want to heat the axle.
Before I took them to a machine shop to have them pressed out I decided to give PB-Blaster a try. For a week I shot them every night and let them soak. This morning I was able to drive the old king pins out using a smaller diameter king pin that I removed on an earlier project. Took abut 15 minutes a side. Of course I did a victory shuffle across the garage to celebrate.
Seems to be good stuff. | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | I'm gonna use that stuff when I do mine.  | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | Better stuff than PB is KROIL from Tenn.This will make ya belive in the real thing.Great stuff also . its the best Ive found.Give it a try
dan-pa
| | | | | Joined: Feb 2004 Posts: 29,804 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,804 | Ditto on the Kroil! www.kanolabs.com Jerry
| | | | | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | I have never tried Kroil, but if it works better than Blaster it has to be great stuff. 1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | | | | Joined: Jan 2007 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 176 | I love the PB blaster that's the best we have around here. love to get my hands on that KROIL. never seen it around here.
1970 C50 dump! saving orphans from the CRUSHER
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Isn't Jack Daniels made in Tennessee too..I wonder how that would work? Stuart | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I have used both, and have both on my shop work table but I do prefer the Kroil and have for years. Pehaps the difference is that Kroil is nothing but PENETRATING oil while PB blaster has something about "lubricating" on listed on the can I have. Pehaps this is why I give Kroil the edge over PB? Someone here on the bolt did a test not long ago on some bolts and also said Kroil was a tat better. Oh well, if it works use it. I might add that Kroil is expensive!! | | | | | Joined: Feb 2004 Posts: 29,804 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,804 | No, No, No! Jack Daniel's is the busted-knuckle painkiller! One of Kroil's major customers is the US government. It was available in the USAF supply system worldwide 30 years ago when I was a GI, and probably long before that. Good stuff! Jerry
| | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | thing i like about pb is its only 3 bucks a can but the gas runs out before all the pbs out of the can wish they would fix that | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Please don't waste the Jack. I used Airo-Kroil when working aviation. Great stuff even had some success using it on guild stainless. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Been using Kroil for 30 years, in fact the spray can I had was thirty old and still had pressure in it. When I started on my 3604 in September I bought an assortment from them. I now have enough Kroil to last me for another 90 years! It goes a long way and that pans out to inexpensive in my book. I don't know what it has in it but it really works great. If you give it a few soakings and let it set a spell, those rusted nuts just spin right off. I have disassembled almost all of my 56 year old truck’s undercarriage this winter and not broke or twisted off one nut or bolt. There was always a big can of “Liquid Wrench” around the shop when I was growing up but it do not hold a candle to Kroil. I've never tried PB Blaster, but, after all who needs it when you can, "Kroil it, don't spoil it". getting your hands on it is just as easy as ordering it direct online, that's how i got mine and they are always running package deals. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | I have used PB Blaster too. Great stuff. I use it to get out of bed every morning........ I get stuck harder than any king pin, especially when it's still dark when I get up. Haven't tried the Kroil, but have heard it was really good. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Jan 2007 Posts: 13 Junior Member | | Junior Member Joined: Jan 2007 Posts: 13 | PB Blaster is Great... I'll try Kroil...but it will be hard to beat PB...anywho...my2cents
If it's not a Chevy, its just a four letter word... you choose which one.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Denny, it hasn't been quite 30 years yet but I"m counting. The last company I worked for, over 15 years, did some trials of their own and they used Kroil exclusively. I have two quart bottles of it that I use to fill a small spray bottle I keep on my work bench. I hope I live to use it all up. I'll be 114 years old by then. Whoopeee. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Just got a flyer from Kroil today and they have a sale on: Titan "2 for 1" Deal. 2industrial Sixe 16.5 oz. cans for $16.00 S&H included. 1-866-774-9541 or Email: [email protected]Denny Graham Sandwich, IL
| | | | | Joined: Jun 2006 Posts: 91 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 91 | Congrates on the pins. I gave up and took mine to a shop. While using unreasonable amounts of heat, they could not remove them with their 20 ton press. As I heared someone else comment "If the pins detech a weak spirit, they will not budge." I ended up using a 50 ton press,lots of PB blaster, and wrecked my nerves but the job is done.
Never used the Kroil but I do like PB. I will never buy WD40 or Liquid wrench again. | | |
