2 members (dt235sd, 1 invisible),
99
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,127 Posts1,056,679 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | My truck came sans data plate...I bought a new one and stamped the VIN. I understand it is mounted on the passengerside cowl. Can anyone give me a more exact location/dimensions for the plate mounting? | | | | | Joined: Nov 2000 Posts: 1,970 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,970 | I have seen an illustration of it somewhere but I don't remember where. I would think there would be 2-4 small holes that match the holes in your new plate.....
Professional Novice
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | There should still be the original mounting holes to help you locate the plaque. My 46 had two different plaques one above the other. I'll have to look through my pics or can snap a new photo if you want. Best of luck Jim | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Should be two holes there where the old one was. On the '39 thru '46 trucks, the green box shows where the tag should be. [img] http://oldtruckstuff.com/4146vintag.jpg[/img] This is an image Peggy sent me a few weeks ago along with some other VIN related information.. I stuck the green box on the image just to make it a bit clearer as to where the tag could be found. The tag would be oriented with the 'top' of the tag pointed twards the grill.
| | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Also, if you don't already have one.. Here\'s a link to a 1942 Chevy Truck owners manual Doesn't have any illustration regarding the 'Data Plate' location.. but since you have a '42 truck, it might be neat to look thru.
| | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | As far as mounting.. here's what the plate outta look like. [img] http://www.oldtruckstuff.com/PLATE42T.jpg[/img] You normally have two holes in the plate, repops sometimes come undrilled. There is usually a little 'intent' as seen in the picture above.. one on the top right and one on the bottom left of the plate. You should be able to find holes in the cowl area of your truck that line up with those locations on the plate. When installed, the top right screw would be twards the ground.
| | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | A plate on a 46... Take a look at this webshots pic. Just confirming what fumblin posted...If you look carefully, there are 4 holes. The top set is visible (hard to see, but there). Use the bottom set. The holes on the plate will match the holes on the truck. | | | | | Joined: Mar 2005 Posts: 284 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 284 | My 42 being a former army vehicle had the plate on the glove box. Now I know exactly where it goes. | | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | Does anyone know what the "upper" two holes were for? On my truck, I thought that somebody must have removed the vin when painting and decided to mount it lower for some reason. Apparently this isn't so? | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | I have no idea.. i've seen a whole lot of old '39 thru '46 trucks and never saw a plate mounted in the 'top hole' position.
Maybe they're left over from a step during the original assembly process?
| | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Steveg:
Just in case you haven’t received enough help yet. There is nothing in the upper two holes on my ’41 either, Top of plate to the front of the truck. Mounted with two fasteners one on the top towards the front of the truck and one on the bottom toward the back of the truck | | | | | Joined: Nov 2004 Posts: 2,420 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,420 | Yeah, good point they are mounted sideways. At least in my eyes.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | Thanks for all the help...I also understand that the plate was mounted with two small clutchhead screws..is that true? Where would you find tiny clutchhead screws? | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Check any of the old truck parts houses. I got mine from Chevs of the 40's. They had #8X32 and #10X32 | | |
