4 members (RoadsScholar, Peggy M, Otto Skorzeny, 1 invisible), 137 guests, and 3 robots.
Topics128,083
Posts1,055,967
Members48,430
#225793 01/26/2007 10:00 PM
Riding in the Passing Lane
For us Kansas City area Stovebolters there are a bunch of S-10 T-5 5 speed trans. at Pick & pull. Some are mechanical speedo,s & one is laying there just to cut a couple of cables & drag it out.
1972 Chevy c10 Cheyenne Super
#225794 01/26/2007 11:23 PM
Thanks for the tip. I was researching improving my 3/4 ton driveline earlier today.
There could be a T5 in my future.
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
#225795 01/27/2007 3:33 AM
Could you grab one for me and I will come down and pick it up? Thanks.... I'm near Des Moines.
Toxictiki
'59 Apache 3100 panel (235)
'51 Chevy Fleetline Deluxe (216)
'48 Binder KB-1 (flathead 6)
'77 Cadillac DeVille (425 donor)
"Once I was 'Chairman of the Bored' then I bought a Stovebolt."
#225796 01/27/2007 4:06 AM
Hey George,
Got any NV4500's down there (2WD)? I'll be looking for a H/D overdrive for my COE in the near future. They have the PTO drive on them still, right? I'm still gonna need my hydraulics,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#225797 01/27/2007 5:39 PM
Just a thought....when you grab your T5, be sure to get the driveshaft too. With my Camaro Diff. and 85-T5, relocating the spring perches back 1" to center the wheel in the wheel well, would let you use the stock S10 driveshaft without modification. You need the front yoke anyways and the rear S10 is compatable with the Camaro yoke. Even if you don't run a Camaro diff. you can use the 2 yokes. I love a bolt-up!!!!
Also, on the mechanical T5's there is a little
adaptor that screws into the speedo fitting. It lets you swap little gears to calibrate your speedo. You'll need that too! Hope this helps.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#225798 01/27/2007 10:08 PM
Quote
I,m too old to pull & handle one by myself but if you come down some morning we can work together & get 2 of them. One each. George [email protected]
#225799 01/28/2007 5:01 PM
Toxi. I think I sent a reply to your private message. Let me know if you got it. [email protected]
#225800 01/28/2007 5:04 PM
Quote
Originally posted by 48bigtrucks:
Hey George,
Scott
It,s pretty rare when one of the larger trans. show up in those places & they are already gone whenever I see the trucks.
#225801 01/29/2007 1:06 AM
I suppose, guess I'll just have to go to the big yard and spend the big money for one.
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
#225802 01/30/2007 6:31 AM
I want an overdrive BUT I don't want to cut out the floorboard of my bolt.
So if you want an overdrive, and a stock look...
.. What is plan B?
Cliff59
Deluxe \'52, Savoy \'54 Apache59
"She may not be the youngest girl at the ball, but she can still turn a head or two."
#225803 01/30/2007 6:40 PM
Junior Member
Junior Member
Thanks for the heads up. U pick it.....Oh the memories of lying on your back in the gravel with strangers stepping over your legs..... eek
Better wear your booties cuz its cold out there!!!
That portion of the floorboard is a removable/replaceable piece is it not?
#225804 01/30/2007 11:27 PM
I put a 4 speed shift lever on mine & it looks like factory 4 speed. Plan C would be an auto o-drive.
#225805 01/31/2007 5:35 AM
Auto Over drive huh? ... hummmmmm
Cliff59
