2 members (PAUL Berardi, carbking), 160 guests, and 2 robots.
Topics128,081
Posts1,056,078
Members48,434
Okay I think/thought I got a deal on an automatic steering column on E-Bay for my '65 C-10, it's an automatic column out of a '67-72 C-10. After bidding and buying the column I started looking closer at the photos... I don't think the actual steering column rod is in the one I bought... can I just use the one from the manual column or did I just buy a $25 part to throw on the scrap pile?
Thanks.
Lee
1965 Chevy C-10 Gallery page
My Chevy truck pages more info and pictures!
1961 Studebaker Hawk
1962 Shasta 16' AirFlyte Travel Trailer
1941 Case Model S tractor
Are you talking the center steering shaft or the shift linkage rod? I don't think the steering shaft will interchange, the older column has the shaft going all the way down to the steering box with the rag joint built in where the newer one stops at the end of the column and is splined for an intermediate shaft,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Thanks... anybody want to buy a '67-72 steering column?
Junior Member
Junior Member
Are the upper and lower bearings good?
No clue, I haven't gotten the column yet.
Lee
Drill out the plastic pins,cut off end where rag joint goes, weld your old one on( if you are using original steering box). bolt on. There!
blu 64: Thanks!! I'm going to be switching over to power steering but it sounds like this may not have to end up in the scrap pile if I take my time and actually look over what I have.
Lee
The center steering rod will swap from the adjustable length to the non-adjustable, from 63-66 solid shaft into the later 67-72 column, like blu64 said just adjust the length if neccessary, no welding is needed tho. The rag joint will work if used on the same box, i.e. some later model power boxes have a smaller input shaft than others. Should be a darn near bolt in, the only real diff is where it mounts to the dash-either weld on 2 new nuts or use sheetmetal screws to mount. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
LeeA:
For sake of originality, try finding a factory original '64-'66 Chevy automatic steering column. I have replaced a few non-original steering columns on a few of my '64-'66 Chevy trucks with original used replacements bought on eBay. This route is a bolt-on and does not require shaft/rag joint modifications. Good luck with your project.
Tony
get a set of flaming river connectors and you can use the old "D" shaft to connect it all together.
Another quality post.
Real Trucks Rattle
