7 members (MickeyP, RoadsScholar, Gdads51, 1955 1 Series, thekid1950, tclederman, klhansen),
117
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,068 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 18 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 18 | Does anyone know if there is a window kit to convert a small back glass cab into a big back glass cab. About 2 weeks ago I was at a local cruise nite, and in talking to another stovebolter he said that he had read an article in (he forgot) a magazine that had an article on how to purchase a window kit. If anyone knows of this kit, or what magazine article, or any supplier that would have these available, I would like to know so I could undertake this project. I have a '64 C-60 2 ton, one owner, with NO RUST, and I really want a big back glass. Please e-mail me with any info. [email protected] Thanks, Warren
Warren L. Seiz Phoenix,AZ
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Warren: Converting the '60-'66 Chevy truck from a small back glass to a big back glass is not done with a kit. It is all custom fabricated hand work. The following tech article will give you a play-by-play of the process. http://www.classictrucks.com/tech/CL_0309_OldSchool/index.html Good luck and I hope this helps. Tony | | | | | Joined: Mar 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 92 | All it takes is a new inner cab panel, the glass and a new window molding. Of coarse you will need to cut the outer sheet metal to the large window demensions. I saved a big back window inner panel from a 66 that I scrapped but Arizona is a long ways from me, Scott | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | You might want to think twice about the big back window seeing's ta how you live in Phoenix. It's going to be like sitting under a huge sun lamp cooking the back of your head. | | | | | Joined: Jul 2006 Posts: 183 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 183 | Ran into this in my wanderings, remembered your question. Not sure if its what you needed. http://www.goodmarkindustries.com Cab Rear Panels 4141-490-551 1955-59 Pickup (without large rear window) 4141-490-552 1955-59 Pickup (with large rear window) | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | | | | | | Joined: Nov 2005 Posts: 266 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 266 | Classic Trucks had an article a few months ago on converting a 60-66 to a big back window. Big Window Conversion Its a rather good write-up on the conversion. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I'm tellin' ya, all you need is a donor cab with the big back window to rob the inner sheet metal panel from. It's just spot welded in. I'm going to the big window on my 63 and I saved an inner panel from a 66 also. If anyone wants to do this conversion, come and get it, Scott | | | | | Joined: Jan 2007 Posts: 18 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 18 | OK Guys, thanks so much for all of the articles, and input. Next question, does anyone know who has and sells inner cab panels for the big back glass??? Let me know, Thanks again, Warren
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if anybody makes that patch, it'll be Dynacorn Bill | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | Find a rotted out big back window cab and cut it out.
-W | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | There are no inner cab panels for converting the small back glass to a bid back glass. A donor cab or hand-fabricated panels are the only options, as shown in the Classic Trucks conversion article. I see '60-'66 Chevy truck cabs with the big back glass on eBay. I have purchased a couple myself. Good luck with your project. | | |
