1 members (tesa), 142 guests, and 2 robots.
Topics128,080
Posts1,055,953
Members48,430
#225357 01/22/2007 5:22 AM
1 Offline
Does anyone know if there is a window kit to convert a small back glass cab into a big back glass cab. About 2 weeks ago I was at a local cruise nite, and in talking to another stovebolter he said that he had read an article in (he forgot) a magazine that had an article on how to purchase a window kit. If anyone knows of this kit, or what magazine article, or any supplier that would have these available, I would like to know so I could undertake this project. I have a '64 C-60 2 ton, one owner, with NO RUST, and I really want a big back glass.
Please e-mail me with any info. [email protected] Thanks, Warren
Warren L. Seiz Phoenix,AZ
Warren:
Converting the '60-'66 Chevy truck from a small back glass to a big back glass is not done with a kit. It is all custom fabricated hand work. The following tech article will give you a play-by-play of the process.
http://www.classictrucks.com/tech/CL_0309_OldSchool/index.html
Good luck and I hope this helps.
Tony
All it takes is a new inner cab panel, the glass and a new window molding. Of coarse you will need to cut the outer sheet metal to the large window demensions. I saved a big back window inner panel from a 66 that I scrapped but Arizona is a long ways from me,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
You might want to think twice about the big back window seeing's ta how you live in Phoenix. It's going to be like sitting under a huge sun lamp cooking the back of your head.
Ran into this in my wanderings, remembered your question. Not sure if its what you needed.
http://www.goodmarkindustries.com
Cab Rear Panels
4141-490-551 1955-59 Pickup (without large rear window)
4141-490-552 1955-59 Pickup (with large rear window)
She's one 55 year old with a spare tire that looks good!
It's not rocket surgery. . . .
http://www.picturetrail.com/fredoly
http://www.cardomain.com/ride/2412127
Socket Breaker
Socket Breaker
Classic Trucks had an article a few months ago on converting a 60-66 to a big back window.
Big Window Conversion
Its a rather good write-up on the conversion.
I'm tellin' ya, all you need is a donor cab with the big back window to rob the inner sheet metal panel from. It's just spot welded in. I'm going to the big window on my 63 and I saved an inner panel from a 66 also. If anyone wants to do this conversion, come and get it,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
1 Offline
OK Guys, thanks so much for all of the articles, and input. Next question, does anyone know who has and sells inner cab panels for the big back glass??? Let me know, Thanks again, Warren
if anybody makes that patch, it'll be Dynacorn
Socket Breaker
Socket Breaker
Find a rotted out big back window cab and cut it out.
-W
There are no inner cab panels for converting the small back glass to a bid back glass. A donor cab or hand-fabricated panels are the only options, as shown in the Classic Trucks conversion article. I see '60-'66 Chevy truck cabs with the big back glass on eBay. I have purchased a couple myself. Good luck with your project.
