1 members (Hotrod Lincoln), 57 guests, and 1 robot.
Topics128,094
Posts1,056,066
Members48,433
1 Offline
How does the conduit connect between the truck and tail light assambley ? I got new lights & brackets & conduits. I put everything together and cant figure it out
Todd
Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs.
1951 3100 350 TBI Gallery Toddzilla... "$old"
Take the light assembly off the bracket. Slide the conduit in through the round hole in the bracket. There is one end of the conduit that has a flange on it. That sets in the hole of the bracket. When you put the light back on it will hold it in there. Somebody else will have to fill you in on the other end. Haven't figured that part out yet.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
I bought a set and couldn't figure it out either so don't feel bad. Didn't ask questions either. Still have them if anyone would care to make me an offer.
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
1 Offline
Well at least now I dont feel that bad it now . The chrome conduits would look sweet but It looks like it will be some nice black heat srink instead "Its all about the detail" nice n clean
Todd
Just a guess, but I bet the other end floats in the hole drilled in the bedside. If the hole is snug, the conduit shouldn't move too much. If required, a tie-wrap around the end under the bed will keep it from coming out. The springy ones for doors are only secured at one end.
I mounted mine under the bed using one of those rubber covered Adell clamps. Holds it nice and secure so it doesn't flop around. I'll post some pix of it as soon as I can take some.
Bill Burmeister
tie ties and tape
Another quality post.
Real Trucks Rattle
Bill Burmeister
Junior Member
Junior Member
last summer i wired my 53 gm 3/4 ton and i got ssooooo tired of feeding wire into that loom but it sure do look perty when its done its hard to beat rubber gromets tohold the loom in place (thru sheet metal, head light buckets etc)
