7 members (baldeagle, Hush, mick53, Southerntruck, SmalltownTRKGuy, Hotrod Lincoln, Gray_Ghost),
102
15
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | How does the conduit connect between the truck and tail light assambley ? I got new lights & brackets & conduits. I put everything together and cant figure it out Thanks Todd Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | Take the light assembly off the bracket. Slide the conduit in through the round hole in the bracket. There is one end of the conduit that has a flange on it. That sets in the hole of the bracket. When you put the light back on it will hold it in there. Somebody else will have to fill you in on the other end. Haven't figured that part out yet.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
| | | | | Joined: May 2001 Posts: 709 Shop Shark | | Shop Shark Joined: May 2001 Posts: 709 | I bought a set and couldn't figure it out either so don't feel bad. Didn't ask questions either. Still have them if anyone would care to make me an offer.
Bruce Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten) New Toy: 1962 Impala SS Coupe The Driver: 1990 Toyota truck
| | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | Well at least now I dont feel that bad it now . The chrome conduits would look sweet but It looks like it will be some nice black heat srink instead "Its all about the detail" nice n clean Thanks Todd Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Just a guess, but I bet the other end floats in the hole drilled in the bedside. If the hole is snug, the conduit shouldn't move too much. If required, a tie-wrap around the end under the bed will keep it from coming out. The springy ones for doors are only secured at one end.
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I mounted mine under the bed using one of those rubber covered Adell clamps. Holds it nice and secure so it doesn't flop around. I'll post some pix of it as soon as I can take some.
Bill Burmeister | | | | | Joined: Dec 2002 Posts: 3,441 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,441 |
Bill Burmeister | | | | | Joined: Jan 2007 Posts: 8 Junior Member | | Junior Member Joined: Jan 2007 Posts: 8 | last summer i wired my 53 gm 3/4 ton and i got ssooooo tired of feeding wire into that loom but it sure do look perty when its done its hard to beat rubber gromets tohold the loom in place (thru sheet metal, head light buckets etc) | | |
