1 members (baldeagle),
158
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | How good or bad is driving a stove bolt with a 4 speed granny and a 4:10 posie in the snow and ice? 3/4 longed. 2 wheel drive My only snow experiences are in a Plymouth fury, 74 Civic and a Chevy s10
I know my 66 GMC has touchy stock power brakes, which isn't good on the ice. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I use to drive my old bolt in the snow and ice.It got around pretty good.My truck is a 1951 3100 chevy.At the time it had the original rearend and three speed on the tree.I use to put sand bags in the bed,over the rear axel. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | my bolts both work fine in winter conditions , with lug tread on back - sometimes I put weight in if the roads aren't plowed Bill | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | My 38 doesn't get out in bad weather. My old 55 panel used to love the snow. I put 700 16 mud grips on the back & she never did get stuck.
| | | | | Joined: Apr 2006 Posts: 236 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 236 | I never had problems in the snow as long as I put chains on.
58 Fleetside, 235, "The Old Buckin' Bronco"
| | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | If you have a posi,you're already ahead of the game.You might want to remember,though, that if the posi unit's set up a little on the tight side,the truck may be reluctant to turn on extremely slick roads,so try to leave yourself a little room to compensate in case it wants to push a little. Usually,just starting your turn as gradually as possible will get you around corners fine. Probably won't be an issue at all. Also,drive no faster than your defroster is capable of working... Speed | | | | | Joined: Oct 2005 Posts: 688 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 688 | No problems here in Mineral Wells. When the ice and snow float down I just grab a few sandbags.. ..toss em in the bed and drive SLOWer. Cliff59 | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | My '53 6500 wrecker is good in the snow using 900/20 military tread tires and weight on the rear.We had a '72 Chevy C-30 wrecker V8 with a 4:11 posi rear that was a real snow hound.Northeast rust go to it and we had to sell it.My new Hino flatbed is real bad in the mud and snow even with lug tires.I have a set of dual wheel chains that I can use if the weather gets bad.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | I've got new, none-too-aggressive M&S radial tires on mine. We have around 2 feet of snow down now, and I unloaded the driveway into my Stovebolt's box. Now she's unstoppable, until there's so much snow packed into the grille that the radiator's job is impeded and she starts to heat up. 1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | Posi might be a little tight, it usually puts out a cherp when I hit a corner hard and fast. This is my first posi truck. I had a 72 VW square back that could be considered posi, She got around good in the snow especially with a full gas tank. | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | I haven't had a bit of luck with driving old 1/2 ton trucks around in mud and snow.. but I suppose the bologna skin tires don't help much.
The '46 2 ton with those big duallie tires on the back dig right in and go in mud and snow just fine.. but it also sits up quite a bit higher.
I was thinking of making that 2 ton truck my snowplow truck for the driveway.. that's how good she does in snow.
For 1/2 and 3/4 ton trucks, I recommend good snow tires on the back, and weight in the bed.
A lot of the old timers around here who drove those trucks when they were new tell me it was common practice to put wider tires on the back during winter for extra 'grab' power.
| | | | | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | In Wyoming, the tire of choice during the winter were THIN snow tires. We called them pizza cutters. The altitude at the town I'm from is 7k. Lots of snow. The wide ones were too slippery on the ice. Almost all the trucks there are either posi or 4wd. | | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | My only experience with snow driving was in 1951 when I started up the Sandia mountains near Albuquerque. I was driving very carefully in my brother's '51 and keeping it on 20 m.p.h. was doing fine until I looked and the trees beside me weren't moving and then started moving backwards. I aimed the back bumper at a tree close to the road and then bro. and I got out and pushed the front end around then went back down the hill. Incidentally I never did get to the top of that hill, well really a mountain, about 9,000 ft. elevation, but the '51 did get us down safely. | | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | I agree bigmacdaddy, wide tires tires sit on top of the snow/ice whereas skinny tires dig in better. | | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | Idrive my 51 year round.When the snow comes i put 3 sand tubes in the back,one over the axle and one lenghthwise over each tire.Iice fish and often drive through a foot of snow on the lake with no trails and no worrys.Ialways back up a couple of feet on my tracks when i stop and have never been stranded.
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | | | | Joined: Apr 2005 Posts: 313 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 313 | THIS one NEVER got stuck in snow or mud. | | | | | Joined: Nov 2004 Posts: 2,409 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,409 | My advice is good snow tires, and at least 500 lbs of weight over the rear wheels. Twice the weight (1000 lbs) would be better yet.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | Yep. I ran a Camaro years ago that only needed 300# over the drive axle: I used sandbags. My stovebolt needs more than that. Slow..Rider has the best idea in his sand tubes, but a bag is nice, too, because on that one time you do need it, a little sand under the tires is as good as chains, and cheaper. Bigmacdaddy is also right. Those great big tires are useful in sand or soft mud, but otherwise pretty much decorative. In snow, ice or rocky ground they render a good truck completely helpless. Sometimes on warm ice, like in spring, a man can actually push a truck with those tires sideways on flat ground with all its wheels locked. The best tires for snow, hands down, are tactical tread. Narrow, high-profile military tires. Second best - and easier to live with - is a full set of high, narrow M&S radials with an aggressive (lumpy) tread pattern. In soft snow, with a little weight, you can drop the drive tire pressures to distribute the weight and lengthen the contact patch and she'll pull like a bulldozer. 1951 3800 Be the change you want to see. -hotshoe
