2 members (Otto Skorzeny, 1 invisible),
136
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,109 Posts1,056,266 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Guys, I am thinking about using a electric fuel pump on my 350 SBC. What are the pros and cons on this issue?
~Jim
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I like a mechanical one if it fits your application. I think that they are simple and very trouble free. I think electric ones take a simple job and complicate it. With mechanical if the engine turns it pumps, there are only two check valves and a diaphragm, if it does not work it is easy to troubleshoot. I have never had a problem with a mechanical fuel pump when using good gas and a filter before it. I have never used an electric one, so my opinion is one sided. I would only consider an electric one if the mechanical could not deliver the required amount of fuel or pressure. | | | | | Joined: Apr 2005 Posts: 313 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 313 | I recently had to replace an electric pump in my car, and it cost about 10 times more than the mechanical one in my truck. | | | | | Joined: Oct 2006 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 26 | If your stuffing the 350 into a small engine compartment then electric is the way to go...you'll save a little clearance. If not then I'd stick with the mechanical fuel pump. They are reliable, cheap, and easy to get on and off without lifting or crawling under the truck.
Of course if the 350 is fuel injected you'll have to go with electric in-tank fuel pump. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | And as always remember if you get in an accident the electric will keep pumping gas as long as it has power, while a mech will only pump it if the engines turning. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | D__n good advice guys! I figure I'll be using a mechanical unless I run out of room.
~Jim
| | | | | Joined: Jan 1970 Posts: 365 Shop Shark | | Shop Shark Joined: Jan 1970 Posts: 365 | I like the electric pump for vehicles that are not used every day. Turn on the key, let the pump build pressure, and the carb is full of gas. The engine starts much quicker with much less strain on the starter and battery.
An electric pump could also be used as a theft-deterrent--a hidden power switch to the pump would greatly cut down on the distance a thief could drive a stovebolt--assuming they could figure out the stomp starter. | | |
