| | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | I'm thinking about getting a hoist. Anybody got an opinion (thats a dumb question) on a good one? Not going to be lifting any big bolts but don't want to limit it to little foreign cars either. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I got the 2 post unit with arms that swing under. My big problem is that it's outside (had to pour a new concrete slab) and will be shoping for one of those RV covers. With the four post/ramp style you can move it around pretty easily inside and out. I think your garage, barn or building is the first issue, just wish I had the bigger shop. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Beware of cheap lifts made in china. I've seen pics of cars seriously damaged after a cheap lift failed. There are a number of quality lifts available. Most 7-10K lb. lifts will set you back over $2K. Personally I'm partial to Bend-Pak.
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I like the "Back Yard Buddy" myself. They will send you a free video if you request it. They talk about the different types of construction of other brands too. Here is the web site. http://www.backyardbuddy.com/ | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | Let's continue this in the tool shed.... | | |
