0 members (),
37
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 183 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 183 | I'm right in the middle of replacing the window regulator which doesn't work with a new one. When we took it out, one of the rivets is covered by the part with the teeth. I can't seem to move the part with the teeth because the regulator is not working. Any suggestions? What's the best way to put the new rivets in without the right tools?
I also was trying to put in new hood springs to replace the piece of wood. I got one in but just can't get the driverside one in. Is there any trick that works? | | | | | Joined: May 2006 Posts: 679 Shop Shark | | Shop Shark Joined: May 2006 Posts: 679 | I don't have answers, but I'm watching for them. I hope to have the same work in a year or so and would probably ask the same question you are.
Bill | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | that window regulator question is unclear - can't you cut the rivets from the other side? once you rip it apart, the teeth should move - best way to repair those things is replace the whole works there ain't a "best way" to do something wrong! if you don't have a way to swedge the rivets, use short screws for the hood spring, grab the loose end with a pair of vise grips and brace yerself - might need someone with more pull to get it Bill | | | | | Joined: Aug 2005 Posts: 183 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 183 | My friend ended up cutting 2 of the 3 rivets and it moved so that worked out. The new regulator sorta fits in the place of the old one. I'll vice-grip it and hammer then ends of the rivets so they mushroom. Hopefully that works. I guess if I mess it up I can buy the whole thing. My friend wanted to use short screws so we might go that way too. We've had so much rain with wind that too much rain was blowing into the cab through the open window. | | | | | Joined: Nov 2006 Posts: 35 Apprentice | | Apprentice Joined: Nov 2006 Posts: 35 | Hey Blue, just a thought here, but Sears sells a pop-rivet set that has an assortment of rivets, some with close tolerance heads. Again, just a thought.
If practice makes perfect, and nobody is perfect, then what's the point of practicing???
| | | | | Joined: Aug 2005 Posts: 183 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 183 | Thanks DearthVader - I should have done that. After doing this I'd recommend buying the whole thing instead of just the crank part. We assembled it and realized the part with the teeth wasn't connected to the crank and couldn't unless we took it all apart again. Sawed off the ones I did and redid it with small screws and nuts. The piece with the teeth covers one of the rivet spots so its impossible to do anyways. I put it all back again and the window goes up and down.
One problem is that when I lower it to its almost lowest spot, the window tilts to the outside of the door. I'm not sure why. I have to yank it back into position. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I used pop rivets when I put the cover back on mine. I checked the shear strength of the steel rivets in my aircraft mechanic handbook and they showed it would be fine. You can always get soft rivets and pein them with a punch. | | |
