5 members (Jon G, Otto Skorzeny, Hanks custodian, dt235sd, 3800GUY), 166 guests, and 1 robot.
Topics128,105
Posts1,056,205
Members48,436
I am considering replacing my cab mounted gas tank . I am looking at getting an under bed floor rear mounted poly tank for the 63 - 66 trucks . Has anyone done this ? It looks like it hangs lower than the differential in any pictures I have seen . The one I am looking at is 13" deep . Any experiences anyone want to share ?
It will stick a couple of inches above the frame, then the thickness of your frame which would be 4" to 7" then the left over 4" to 7" would hang below the frame. It may be a problem on a lowered truck. My 63 is a jacked up 4X4, so this wasn't a problem for me,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
That is not so bad . I had measured down from the bottom of the frame and thought that would be pretty low . I would have to remove the small crossmember in that area to get it to go between the rails , but that should be no problem . Thanks .
