7 members (cmayna, Leo, Hotrod Lincoln, Mike in Sycamore, Gdads51, 1955 1 Series, Bill Trotter),
127
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,113 Posts1,056,280 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2003 Posts: 28 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 28 | I am considering replacing my cab mounted gas tank . I am looking at getting an under bed floor rear mounted poly tank for the 63 - 66 trucks . Has anyone done this ? It looks like it hangs lower than the differential in any pictures I have seen . The one I am looking at is 13" deep . Any experiences anyone want to share ? | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | It will stick a couple of inches above the frame, then the thickness of your frame which would be 4" to 7" then the left over 4" to 7" would hang below the frame. It may be a problem on a lowered truck. My 63 is a jacked up 4X4, so this wasn't a problem for me, Scott | | | | | Joined: Jul 2003 Posts: 28 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 28 | That is not so bad . I had measured down from the bottom of the frame and thought that would be pretty low . I would have to remove the small crossmember in that area to get it to go between the rails , but that should be no problem . Thanks . | | |
