| | | Forums66 Topics128,012 Posts1,055,320 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 120 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 120 | What is ususlly used to connect cable ends with a ball on end. I've looked in auto parts and hardwear stores and can conjure up ways to do it but there must be a standard way-- I would guess the cable ball goes through a hole and then slides down a slot on some connecting gadget. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Actually, you've got it mostly right. The ball goes through the hole, then down the slot. No gadget, the ball is what holds it in.
Bill Burmeister | | | | | Joined: Oct 2006 Posts: 120 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 120 | but through the hole of what? I'm looking for the part the cable hooks into. | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Generally, the part (I think Clevis is his name) will be a tall U-shaped piece with a hemishperical pocket at the bottom to seat the swaged ball, and bolt or pin holes at the top. Light duty units will have a slot to put the cable in through the side. Heavier loads require the ball to be swaged after the cable is threaded through the hole (sort of like flaring the brake line with the connector already on)
Check the hardware stores, you may find some the right size.
Good luck
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | redtruck65MA what are you trying to do here?? what cable?? to where?? what application??? throttle - brake - choke ??? what size cable determines what type end & or ball??
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Oct 2006 Posts: 120 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 120 | Thanks Highflyer I'll check it out.
carolines truck I'm putting in parking brake rear cables. The ends that connect to the lever where the front cable is attatched to it is not like the origional. Why? costs less to make probably. Anyway I have to hook it up a different way because the cross member was moved and that is where the pivot point is. I had to find a different shaped lever shaped like a boomerang instead of straight..I used a motorcycle shift lever. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Take a look at the brake levers on just about any bike or motorcycle. That's pretty much the best way. You want positive retention so if the cable slack doesn't get pulled out all the way the ball doesn't fall off the lever.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Oct 2006 Posts: 120 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 120 | I know how the cable ball should be but what I'm trying to find out is when replacing cables what actual part can be found/bought for the cable and ball to hook into. Thanks! | | | | | Joined: Nov 2004 Posts: 2,399 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,399 | If I remember correctly, many years ago, motorcycle cables had a lead ball either melted, or mashed on the end. The ball and cable, then slid thru a disc with a large hole thru one side, and narrowed down to a hole just a little larger than the diameter of the cable.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | On Harleys (late Models) the ball end is slipped into a furel. Then the ball end and furel are slipped into the lever. | | | | | Joined: Mar 2006 Posts: 319 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 319 | Might try a company that does brake cables and also custom work. http://www.inlinetube.com/
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
| | | | | Joined: Oct 2006 Posts: 120 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 120 | Thanks randy,
Wish I had known about this company before ordering cables. If they dont have the parts I need no one does. | | |
