3 members (Hotrod Lincoln, Chip O, Steelonsteel), 125 guests, and 3 robots.
Topics128,196
Posts1,057,391
Members48,471
I just ordered a radiator for my '62, and figuring that bigger is better, I ordered the 3/4-ton radiator. There weren't any dimensions in the catalog about the mounting flange, but in the picture (boy that stounds dumb), the flange on the 1/2-ton radiator looks much wider than the flange on the 3/4-ton radiator.
Of course, after ordering it, I looked at the one in my truck, and the flange doesn't look all that wide.
HOWEVER, my truck was originally a California Forestry Department vehicle, so they might have ordered the bigger radiator with the 283/granny 4spd. Maybe. I hope.
So, will a 3/4-ton radiator bolt to the core support? When I've looked at the reproduction core supports, I've never seen them specified as 1/2- or 3/4 ton, nor have I seen a difference in any other front end sheet metal.
Any info would be appreciated.
Brad
SOUTHERN FALL GABfest
October 6 ~ Commerce, Georgia
Details here!
Never Pee on an Electric Fence.
As far as I know, the radiators were all the same in 1/2 ton and 3/4 ton trucks. They also used the same radiator for the inline 6s and small block V-8s as well. This is all according to my shop manual and owners guide.
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
Junior Member
Junior Member
good deal it should fit. i used a 3/4 ton 66 in my 1/2 ton 66 c10.
There are several different sizes of radiator for these trucks. You may need to find a different top mount for it and move the lower mounts down into the lower part of the radiator crossmember to fit a large radiator where a small was. All of the radiators will fit all of the trucks with the proper mounts,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
