5 members (GMCJammer51, Phak1, Greg_H, WICruiser, tclederman), 93 guests, and 0 robots.
Topics128,117
Posts1,056,296
Members48,439
#214485 08/25/2006 3:48 PM
I know one of you 'bolters is gonna have the solution... the wheels on my truck are 16.5's and take the newer style hubcap (no clips, just the 3 raised 'bumps' that a hubcap would snap over). I measured and it looks like I need an 11 inch hubcap. I want a round style, preferably a baby moon. Any ideas where I can find some that I can order on-line? thanks, randy
#214486 08/25/2006 4:09 PM
you might try this one
link
you might also try the search selector at the top of the page.. just enter hubcabs or what ever and go to the section that you may need,, general truck, engine, etc.........
what yr is your truck?
Redryder pix
My Hotrod
#214487 08/25/2006 6:22 PM
I'm guessing you've a 3/4 or 1 ton with 16.5 rims. I looked into this a bit as I have the same type rim, and there's plenty online. The trouble is the depth. They're primarily made with the 1/2 ton in mind. So, to fit over the rear hub, I had to inquire first about the depth. Either nobody ever bothered to email me back (Paulsen was one of these places), or said, "I don't know. They're in our warehouse." One place gave me actual dimensions. Not deep enough.
I found plenty of new and old baby moons on ebay. Here, it was easy to ask about the depth and sometimes it was even listed in description.
After all my searching, I decided to just have bare rims with chrome lugs.
As far as mounting, I was planning on using hubcap clips which are available from the truck parts places. Weld 'em, screw 'em, or rivet 'em.
-David
Tradin' up dimes for nickels...
My \'65 Chevy C-20
#214488 08/25/2006 6:41 PM
Thanks guys! Yeah, my truck is a '54 3600 pickup and it DOES have the big ol' rear hub sticking out.
Thanks for your ideas... randy
#214489 08/25/2006 7:25 PM
I'm not sure if these'll work, but have a peek .
You probably want to look at TR-144. They are for the 46-53.1 models, but you may be able to get the clippies (they're on the same page) and make them work with your wheels.
Good Luck!
