7 members (Peggy M, mick53, cmayna, Lostbuthaulinass, RaNfLaS, Southerntruck, JW51),
181
0
Mod | | | Forums66 Topics128,114 Posts1,056,285 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 63 Member | | Member Joined: Aug 2005 Posts: 63 | I know one of you 'bolters is gonna have the solution... the wheels on my truck are 16.5's and take the newer style hubcap (no clips, just the 3 raised 'bumps' that a hubcap would snap over). I measured and it looks like I need an 11 inch hubcap. I want a round style, preferably a baby moon. Any ideas where I can find some that I can order on-line? thanks, randy | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | you might try this one link you might also try the search selector at the top of the page.. just enter hubcabs or what ever and go to the section that you may need,, general truck, engine, etc......... what yr is your truck? Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | I'm guessing you've a 3/4 or 1 ton with 16.5 rims. I looked into this a bit as I have the same type rim, and there's plenty online. The trouble is the depth. They're primarily made with the 1/2 ton in mind. So, to fit over the rear hub, I had to inquire first about the depth. Either nobody ever bothered to email me back (Paulsen was one of these places), or said, "I don't know. They're in our warehouse." One place gave me actual dimensions. Not deep enough. I found plenty of new and old baby moons on ebay. Here, it was easy to ask about the depth and sometimes it was even listed in description. After all my searching, I decided to just have bare rims with chrome lugs. As far as mounting, I was planning on using hubcap clips which are available from the truck parts places. Weld 'em, screw 'em, or rivet 'em. -David | | | | | Joined: Aug 2005 Posts: 63 Member | | Member Joined: Aug 2005 Posts: 63 | Thanks guys! Yeah, my truck is a '54 3600 pickup and it DOES have the big ol' rear hub sticking out. Thanks for your ideas... randy | | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | I'm not sure if these'll work, but have a peek . You probably want to look at TR-144. They are for the 46-53.1 models, but you may be able to get the clippies (they're on the same page) and make them work with your wheels. Good Luck! | | |
