6 members (TexasJim50, Cletus1950, Gdads51, Leo, fonz8261, 78buckshot), 70 guests, and 3 robots.
Topics128,179
Posts1,057,068
Members48,460
guys, whats the best rust blaster to spray on stuck rusted screws, bolts and nuts? thanks
I think it is called PB Blaster that I use, it is much better than wd-40
Ed
Kroil.
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
Kroil and PB Blaster are both excellent. We use Kroil to dismantle boiler and running gear parts on steam locomotives. PB Blaster is no slouch either. Both penetrate way better than liquid wrench.
WD-40 is not intended for use freeing rusted nuts and bolts, etc.
Ex Hall Monitor
Ex Hall Monitor
A torch (when you can use it & not burn your garage to the ground) then PB Blaster after it cools a bit. The torch expands the metal, breaking the rust loose & the PB finishes the job.
On rusted nuts that you can't use a torch on a nut cracker works great if you don't care about losing the nut. Most of the time a cracker will not harm the bolt or stud.
I use Brake Free by Dupont. You get it a gun stores. Even Walmart has it in their gun section.
But forget the sissy stuff. Get yourself the longest breaker bar you can (1/2 inch) Craftsman is about $25. Worth it. Nothin will stop you. It will snap the bolt shaft. and thats OK. Was too rusted to save anywise. wink
PB.
Chrysler Heat Riser Valve Penetrant. Available at any Chrysler dealer.
Dave
66 GMC- father /son project with the "GMC KID"
36 Chevy PU- 4x4 lifetime project
64 Skylark- wife says its hers
6 heaven
6 heaven
Before you spray anything on the bolt/nut try to heat it red hot, then keep spraying water on it, the water will boil off at first til it cools, then try to unscrew it. repeat if necessary. Use this method before spraying any kind of lubricant or store bought stuffon it! Works like a charm most of the time.
pb blaster ftw!!
Twist it off with a breaker bar.
BG's Enforce,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
