| | | Forums66 Topics128,110 Posts1,056,274 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 96 Member | | Member Joined: Jun 2006 Posts: 96 | In San Diego. Does anyone know where I might take my 1949 pickup for repairs in San Diego? Need a new clutch. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | With a hand half full of tools and a big hammer, and of course The Stovebolt Page you could do it yourself. And perhaps even have fun. It could be a bonding experience for you and your truck. Unless you use a rivited clutch disk...... | | | | | Joined: Dec 2002 Posts: 3,441 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,441 |
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Let's see.....you're looking for an "Old Chevy Mechanic". So you're looking for an old mechanic that works on Chevys.....or is it a mechanic that works on old Chevys.....or is it an old mechanic that works on old Chevys? Hmmmmm.
| | | | | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | 2000 bucks darn. Rusty you are bad. Hell for 2000 bucks i'll tow it from cal. to texas and return it when i am finished
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Here's a test question for the person you find that says he's an old chevy mechanic: ask to see the tool he uses to loosen the inner nut when changing points and condenser and the special curved wrentch to get the top starter nut/bolt off. If he has the rocker valve lash adjusting tool that looks like a box end wrentch with a spring loaded screwdriver attached--you've found your man.
Evan
| | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Other than having to remove the bolts retaining the torque tube bell, pulling the bell back, disassebling the U-joint(not forgetting to bend back the lock tabs therin) and either tying the torque tube up or letting it drop, the job is very straight forward and any mechanic should be able to do it. I did it when I was eighteen without a manual and having never seen it done, and I was not a trained mechanic. | | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | Changing the clutch is easy and definately something you should do yourself. If not, any mechanic can do it for you. That is the beauty of these trucks, they are easy to work on.
That tranny is heavy though, don't try to do it without a tranny jack.
| | | | | Joined: May 2003 Posts: 9 Junior Member | | Junior Member Joined: May 2003 Posts: 9 |
1972 Chevy Cheyenne
http://pg.photos.yahoo.com/ph/aikidojiujitsu/album?.dir=dbe7&.src=ph&store=&prodid=&.done=http%3a//photos.yahoo.com/ph//my_photos
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I,ve got all those tools. Ship it to K.C. I,m 72 & just bench press those tranies in. Unless its a 4 speed. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2002 Posts: 3,441 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,441 | them boys look expensive...
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I'm old and I'm a Chevy mechanic, among other brands, but I'm not in San Diego. I guess two out of three won't work in this case, Scott | | | | | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | coilover,,,got all the tools in the box but live in Iowa...doc | | | | | Joined: Jun 2006 Posts: 96 Member | | Member Joined: Jun 2006 Posts: 96 | Mechanic that works on old Chevy's is what I should have said. Glad to see my snafu generated so much humor. | | | | | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | You see the thing is you need a mechanic, the term mechanic is used to discribe a person that can repair anything with a pair of plires, 2 screwdrivers and a brass hammer, all in his hip pocket and his pocket rubbing the ground. Everyone else is a technition. Mechanics are a dieing breed. I work for a dealership in texas, I dispatch work to tech.'s. I gave a tech. an old dodge truck with a slant 6 engine. He can repair fuel injection on any car, diag. any computer problem, but his first problem was he didn't know how to shift a 3 on the tree, then after I explained the shift pattern he comes back to me and says,"I don't know anything about points and condenser!?" I laughed my a$$ off.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | | | | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | It can be tricky geting the disk/pilot/trans alignment while working alone on the first job. but can be done. up in aniheim there was a bee-line shop with some true mechanics at work. hope they are all ok.
"It ain't a truck if you can't hose out the cab."
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | hey leon,if guys like you and me don't learn how to do this ourselves then "old chevy mechanics" will become extinct.All of these guys on this site are offering their knowledge for free and if we don't take advantage of it and learn how to fix our bolts then noone will be able to teach future bolters.And it is fun,lots of fun. | | | | | Joined: Apr 2004 Posts: 158 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 158 | In a '49 wouldn't it be easier to pull the engine and work on the clutch out in the open than dropping all the u-joints, etc? I've always replaced my clutch when I had the engine out anyway, so it just seems natural Brian | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | alignment is no problem, They make a little wooden tool for about 4 bucks that does it fine. I'm with the other guys, Do it your self for the fun and being able to say I did it my self. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | If it is a 4 speed the trans has to come off before the engine comes out, so just do it all in the truck. I have not tried a 3 speed, but I suspect the same thing. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | No problem pulling trannys.A four speed will be a lot heavier than a three speed.I use an old input shaft from a transmission as my pilot tool.It helps to have the floor cover pan out of the way.If it is a four speed,you might want to remove the shifter handle before dropping out.
If you need to replace the pilot bushing.
1.use a grease gun and fill the pilot bushing with grease.
2.use a dowel rod that fits just right into the pilot bushing.
3.insert the dowel and smack with a hammer.The grease will force the pilot bushing out.
It's really not hard to do.I did my first one when i was 15 years old.A shop manual will be very valuable to you.
Good luck !!! 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
