5 members (Ridgeback, Otto Skorzeny, 39Master85, 1955 1 Series, Hanks custodian), 80 guests, and 2 robots.
Topics128,079
Posts1,056,286
Members48,441
#209266 06/08/2006 5:44 AM
Hello All, I just pulled a 51 Chevy 3/4 ton outa a field this last weekend. The truck was bought new by my great uncle so it has been in my family for its life. This is the reason that while looking through the truck I found the Key in the ignition. It's got a 235 out of a 56 Chevy in, I was told that it was running when parked. tonight I got a 6 volt battery and dropped it in, turned the key, and nothing. Well I didn't expect anything, however I did get running lights, and a few of my gauges moved. Well I just wanted to tell a few more people how excited I am to have this. In a few month I'll also pull out a 49 GMC 3/4 ton flatbed, also with the key in the ignition.
#209267 06/08/2006 7:24 AM
Hi 51Farm,
WAY TO GO there I bet you will get that Bolt crankin real soon.
Cliff59
Deluxe \'52, Savoy \'54 Apache59
"She may not be the youngest girl at the ball, but she can still turn a head or two."
#209268 06/08/2006 5:06 PM
He Congratulations another one saved and on the road again soon. You already know what I'm asking for I guess ? Pictures, we always wanna see pictures smile
Shop the Tech Tips, some good advice there and if you can't find it there, ask the guys, they know everything.(almost)
Welcome to the Bolt, grab a chair and start reading
CU
Richard
#209269 06/08/2006 11:40 PM
A 51 won't start or crank by just turning the key unless it was modified to do so. Is the old start pedal still on the floor next to the gas pedal?
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#209270 06/09/2006 7:28 AM
If its been a few years, you might pull the spark plugs out and put a bit of oil in each of the cylinders. Wait a few days, and then see if you can bar the thing over. I did that with my 47 jeep and it felt like it had some rough spots so I kept at it till all was smooth. Been running fine ever since. Jeep is easy to do though as it was designed to use a crank if need be.
#209271 06/09/2006 10:27 AM
Irwin,
My brother-in-law has a 54 jeep and she is a bute. that thing takes a beating and keeps on
Jeeping.
I remember when he told me about that cranking feature. I would not have a problem going to Alaska in that Jeep. (it could do it!)
Cliff59
#209272 06/12/2006 1:42 AM
Hey guys thanks, to all the help.
Yes it has the pedal. I also know that is is contacting the button on top of the starter. My next steep is to try to rebuild the starter.
I would like to crank it by a crank bolt, like a SBC, however I can't seem to see any bolt on the dampener, any help there?
I also made a gallery with a few pictures, don't know if it's up yet or not.
