7 members (Wisner955, Otto Skorzeny, Gdads51, 55shaker, Wayne67vert, jay d, Bill Hanlon),
125
Mod | | | Forums66 Topics128,274 Posts1,058,425 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2002 Posts: 31 Junior Member | | Junior Member Joined: Mar 2002 Posts: 31 | I cannot seem to clear up if the engine in my 54 Chevy is a 235 Thriftmaster, or 235 Blue Flame.
Believe me, I wouldn't be cluttering our forum with ANOTHER engine number question if I hadn't tried finding this out for myself. Not even my Master Parts Catalog or Shop Manual clear this up.
I have: 1) The engine block serial number - 0415156T54Z - etched into a machined surface located just aft of the distributor (I do know the T is for the Tonawanda Plant). 2) Engine block casting number - 3835913 GM23 - cast into the block forward of the distributor. Some sites imply the "3835913" portion indicates a "First Series 1955 head." 3) And then there's this third number - C0N1 G164 - cast into the block just aft of the starter.
What the h--- do I have here? :confused:
Cheers from NC!
Spito, spitero, huchtooey splateus! 1958 GMC Series 100 stepside 1954 Chevrolet Bel Air 4-DR sedan 1966 Chrysler Newport 2-DR hardtop
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the difference would be that the car version might have hydraulic lifters, otherwise they're the same deal
Bill | | | | | Joined: Feb 2004 Posts: 336 Shop Shark | | Shop Shark Joined: Feb 2004 Posts: 336 | It's pretty ironic that I found this today. This was the first I heard of it and I was going to do a post. blue flame | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | 600 bucks, not a bad deal.. at first I noticed the 6,000 and thought.........whoa Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | The serial number says (to me anyway) that it is a "Regular" 115HP engine (e.g. no heavy duty clutch, no power steering, et cetera), orginally outfitted with a stick (as opposed to a powerglide).
These were used in all Cars with manual trannies (except for the Corvette) and some of the lighter Trucks (eg 1/2 - 1 ton). If you had a truck, you could order the heavier duty stuff if you wanted.
IIRC, the G164 is a date code -- I think -- that suggests that the block was cast July 16, 1954.
So, to answer your question: My vote is thriftmaster. | | | | | Joined: Nov 2000 Posts: 1,975 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,975 | Have you tried the VIN decoder at American Classic? Try this. Also you can try Keith's online Chevy manuals here. The Z indicates the standard 235 CAR engine.
Professional Novice
| | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Originally posted by Frank50: Have you tried the VIN decoder at American Classic? Try this. Also you can try Keith's online Chevy manuals here. The Z indicates the standard 235 CAR engine. They also used the "Z" engines in Light Trucks. | | | | | Joined: Aug 2005 Posts: 157 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 157 | Yeah, cast July 16, 1954. The CON1 means it was cast on #1 mold conveyor at Tonawanda. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | The "T54Z" is the first listing in my engine ID book (for trucks only). It's a 1954 235 plain and simple. Scott | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | If it's a truck engine the original timing gear would have been aluminum. The car engines used a phenolic gear. That's the only difference.
Fred 52 3600 69 C-10
| | | | | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | The only "light truck" in which the Z engine would have been used was the sedan delivery, which is really a car.
Curt ---- 1953 Chevy 6400, 1957 Chevy 2dr Sedan --"Mediocrity is easy, the good things take time"
| | | | | Joined: Mar 2002 Posts: 31 Junior Member | | Junior Member Joined: Mar 2002 Posts: 31 | Hey, Fredstev:
No.1 Conveyor in Tonawanda?
Where the heck did you find THAT information? That's getting down to some details! Must be some library you have.
Chris in NC
| | | | | Joined: Mar 2002 Posts: 31 Junior Member | | Junior Member Joined: Mar 2002 Posts: 31 | So, it looks like from Keith's online Chevy manuals then (thanks Frank) my original Blue Flame would have had a "ZE" at the end also, because this car also has the original power steering.
So sometime in it's history, an owner swapped out the Blue Flame. Anyway, this engine is strong and climbs the Appalachians like a mountain goat! Think I'll keep it. Besides, a 2-bolt valve cover probably leaked pretty badly.
Fredstev and Brendan, thanks for the casting date code and mold conveyor information (where'd you get that?).
Thanks everyone for all this help.
PS: I'm doing some "body" maintenance to clear up some minor blistering blemishing the previous resto in 1998. I've been trying the POR-15 stuff talked about in Cars and Parts last month and it works really well.
Cheers from Chris in NC!
| | | | | Joined: Aug 2005 Posts: 157 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 157 | Originally posted by whotmewory: Hey, Fredstev:
Chris in NC No library, I worked at the Chevrolet Saginaw grey iron foundry for 36 years. At our place the 6 cylinder blocks came off of #2 conveyor during the period I was there. I think that the service six was produced on the old 7 conveyor. Our small block V8's were poured on #1 and #3 conveyors. Bear in mind that GM (and other auto manufacturers) needed to be able to identify the source of their castings both at the engine plant and later in the vehicle. There are also shift markers and in some instances, the hour of the day the casting was poured. At our place, a flathead 8-32 screw in the pattern meant day shift, and a round head meant 2nd shift. | | | | | Joined: Jan 2001 Posts: 230 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 230 | THANK YOU ! I've been wondering about that for 30 years now.... -Nate Originally posted by fredstev: At our place, a flathead 8-32 screw in the pattern meant day shift, and a round head meant 2nd shift. [/QB]
-Nate There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
| | | | | Joined: Mar 2002 Posts: 31 Junior Member | | Junior Member Joined: Mar 2002 Posts: 31 | FREDSTEV:
36 years? Man, the cars you must have seen in your career! I'd wager you'd enjoy John Robertson's "A Pictorial History of Chevrolet, 1940-1954." ISBN 1-880524-29-5. It's full of GM archives photos we don't usually get to see unless they are in the Taillights page of Cars and Parts.
Chris in NC
| | | | | Joined: Aug 2005 Posts: 157 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 157 | whotmewory - thanks for the book info. I'll check into it.
Just to clear up any confusion on these engine numbers and identifiers - I was a patternmaker at the Saginaw grey iron foundry. All the numbers and identification stuff that we dealt with was for identifying a CASTING and the date that it was cast. With just a few exceptions, marine and service parts engines, all of our output was destined for Flint, MI. Some times, these castings would sit around for weeks, or maybe even a month or so before being machined and having a ENGINE number stamped into them.
We had to be able to identify the shift, date of casting, pattern number, and part number on our castings so if there was a problem at the assembly and machining plant, or later, out in the field, we could pin down the source of the problem.
Patterns and core boxes wear from constant exposure to mold sand. A worn pattern will produce a "smaller" casting in many detail areas that may not have machining cleanup stock. Just the opposite with a core box - a worn one will produce bigger cores that introduces another set of problems.
I guess the point of this is, don't mix up casting information with machining and production information. The stamped engine number is of much more use to the customer than casting numbers.
There, I won't bore you guys any more with this stuff. | | |
