5 members (dt235sd, klhansen, 2-Ton, 52GMC35424JD, Hotrod Lincoln), 79 guests, and 3 robots.
Topics128,049
Posts1,055,665
#208477 05/25/2006 3:50 PM
Junior Member
Junior Member
My daily driver is a modern 1975 C10 with a Turbo 350 behind 350 motor. It is all stock with about 80,000 miles on it. The transmission fluid has never been changed. I would like to switch the transmission fluid out with new synthetic fluid. I have always heard that if Trans fluid has never been changed, then you will cause all kinds of hate and discontent changing it out. Any information on the matter would greatly be accepted.
Todd
cool
#208478 05/25/2006 4:32 PM
If you are changing types of oil you will have to drain the converter and filter also. You will only get about 2 of the 10qts. out by the drain plug.
#208479 05/25/2006 8:57 PM
Don't forget to flush the tranny cooler. Most tranny shops sell an aerosol can w/hose made for this- You screw it into where one of the cooler lines goes and leave the other side open and push the button, this'll clean out the cooler.
What you are going for is to get all the fluid out AND all the dissolved bits of clutch/friction plates...
You should definately change the filter/gasket and think about putting some 'tranny flush' fluid in the tranny before draining it. That'll help get all the fluid out and reduce possible problems from mixing new syn with the older stuff.
What Gazim says about draining the converter too is spot on, in some converters there is a drain plug for that purpose.
It might be easier to have someone else do this for you. I believe tranny shops have a special machine to do the swap and don't charge that much to do it.
#208480 05/25/2006 10:45 PM
Yup, I have little experience in draining the converter
#208481 05/25/2006 11:32 PM
Take it to a shop that has a trans. flush machine. That's the only way to get the fluid changed, even then there's a little "mixing" of the old and the new, but it changes the majority of it. I would worry too much about the synthetic stuff, a TH350 will work well on standard ATF,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#208482 05/25/2006 11:33 PM
Junior Member
Junior Member
Sounds great. I will look into having a shop swap out the fluid for me. Thanks
