| | | Forums66 Topics128,049 Posts1,055,653 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 6 Junior Member | | Junior Member Joined: Apr 2006 Posts: 6 | My daily driver is a modern 1975 C10 with a Turbo 350 behind 350 motor. It is all stock with about 80,000 miles on it. The transmission fluid has never been changed. I would like to switch the transmission fluid out with new synthetic fluid. I have always heard that if Trans fluid has never been changed, then you will cause all kinds of hate and discontent changing it out. Any information on the matter would greatly be accepted. Thanks Todd  | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | If you are changing types of oil you will have to drain the converter and filter also. You will only get about 2 of the 10qts. out by the drain plug. | | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | Don't forget to flush the tranny cooler. Most tranny shops sell an aerosol can w/hose made for this- You screw it into where one of the cooler lines goes and leave the other side open and push the button, this'll clean out the cooler.
What you are going for is to get all the fluid out AND all the dissolved bits of clutch/friction plates...
You should definately change the filter/gasket and think about putting some 'tranny flush' fluid in the tranny before draining it. That'll help get all the fluid out and reduce possible problems from mixing new syn with the older stuff.
What Gazim says about draining the converter too is spot on, in some converters there is a drain plug for that purpose.
It might be easier to have someone else do this for you. I believe tranny shops have a special machine to do the swap and don't charge that much to do it.
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Yup, I have little experience in draining the converter | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Take it to a shop that has a trans. flush machine. That's the only way to get the fluid changed, even then there's a little "mixing" of the old and the new, but it changes the majority of it. I would worry too much about the synthetic stuff, a TH350 will work well on standard ATF, Scott | | | | | Joined: Apr 2006 Posts: 6 Junior Member | | Junior Member Joined: Apr 2006 Posts: 6 | Sounds great. I will look into having a shop swap out the fluid for me. Thanks | | |
