2 members (Wayne67vert, Bill Hanlon), 100 guests, and 2 robots.
Topics128,026
Posts1,055,402
Members48,422
#208392 05/23/2006 8:28 PM
Saw a display of LED tail lights at a show that included the ones we have on the 47-53 Chevy trucks. They were just on a wooden panel and illuminated. However when I was looking at them the salesman turned a switch and said this is how they look when you put on the brakes. I almost went blind! So bright! I started to wonder if in fact they are that bright or did he have some sort of super dynamo hidden behind that panel. They were very impressive and I am tempted.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#208393 05/23/2006 8:37 PM
I scavenged the guts out of a set of new trailer lights and installed them into the stock repopped tail light housings I got from Jimmy...
I still need brighter lamps tho...
Another quality post.
Real Trucks Rattle
#208394 05/23/2006 9:06 PM
I bought some at a show, 39 foooord Installed them and they are great. paid about 70 bucks but have seen them for less in classic truck mag. MIne were so dim that people told me they were out. NOT NOW
#208395 05/23/2006 9:15 PM
I too am installing a set on my 2 ton. According to the electrician installing the LED stoplights in town they are a full 100% brighter than incandecent type.
240,000 worker bees!
1960 Two ton Chevy
#208396 05/23/2006 10:00 PM
2 Offline
I just picked up a pair of halogen lamps from Speedway and installed them in the origenal tail light assy. Had to press the socket a little deeper so the bulb would clear the glass lens. Only cost 8.95 for both lamps. Now when I hit the brakes I have a full 20 watts blairing at you.
Tom
#208397 05/24/2006 4:04 PM
Speedway has the LED taillights in the OEM style housings for the 47-53 trucks for only $30 each, which is what I paid for a non-turnsignals set from CD with incandensent bulbs! They've also got led taillights for many different older cars/trucks.
#208398 05/24/2006 4:52 PM
Bondo Artiste
Bondo Artiste
I got a pair of LED lamps from "Chevs of the 40's" and they are flat out awesome. My truck is 12 volt.
Check 'em out!
http://community.webshots.com/mypho...mp;albumID=464784588&security=ybPaFK
~ Phillip
#208399 05/24/2006 8:42 PM
Mine came from Technostalgia as a retrofit kit into the original taillamps. Much brighter than incandecents and they won't burn out. I'm running APC amber led 1157 type bulbs in the front too, keeps the clear lens with amber illumination. Just make sure to put in an electronic flasher or your signals may not work properly.
Bill Burmeister
#208400 05/24/2006 9:29 PM
If some one wants the hi intensity 1057 bulbs I bought from speedway (a good firm) cost me about $10 I would be glad to send them for the postage and a pair of regular bulbs. They were better but not by much.
#208401 05/24/2006 11:59 PM
what is the link to Speedway?
Blue 50
1950 3100 w/57 235
Patrick’s Saginaw 4 speed and 3:55 rear end
#208402 05/25/2006 5:26 PM
Here's the link to the speedway led taillight/turn signals with the 47-53 housing for $31.95
http://www.speedwaymotors.com/xq/aspx/paging.yes/dept_id.433/display_id.4051/qx/Product.htm
Here's the link to speedway for the LED bulbs if you've already got the housings:
http://www.speedwaymotors.com/xq/aspx/dept_id.433/display_id.3032/qx/Product.htm
And here's the link to the flasher for LED lights, which I believe you can find at any truckstop in america.
http://www.speedwaymotors.com/xq/aspx/paging.yes/dept_id.433/display_id.4372/qx/Product.htm
#208403 05/26/2006 6:25 PM
The site at
superbrightleds.com
has some good info. They also sell the proper load resistors so that your stock flashers and stuff should still work with the LED replacements.
Good luck.
-Joel
'52 3800 Panel
School bus conversion... Glass all around. (check the gallery!)
outside of a dog, a book is a man's best freind.
inside of a dog it's too dark to read.
-Groucho Marx
