| | | Forums66 Topics128,026 Posts1,055,408 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Saw a display of LED tail lights at a show that included the ones we have on the 47-53 Chevy trucks. They were just on a wooden panel and illuminated. However when I was looking at them the salesman turned a switch and said this is how they look when you put on the brakes. I almost went blind! So bright! I started to wonder if in fact they are that bright or did he have some sort of super dynamo hidden behind that panel. They were very impressive and I am tempted. | | | | | Joined: Dec 2002 Posts: 3,439 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,439 | I scavenged the guts out of a set of new trailer lights and installed them into the stock repopped tail light housings I got from Jimmy...
I still need brighter lamps tho...
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | I bought some at a show, 39 foooord Installed them and they are great. paid about 70 bucks but have seen them for less in classic truck mag. MIne were so dim that people told me they were out. NOT NOW | | | | | Joined: Mar 2006 Posts: 89 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 89 | I too am installing a set on my 2 ton. According to the electrician installing the LED stoplights in town they are a full 100% brighter than incandecent type.
240,000 worker bees! 1960 Two ton Chevy
| | | | | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | I just picked up a pair of halogen lamps from Speedway and installed them in the origenal tail light assy. Had to press the socket a little deeper so the bulb would clear the glass lens. Only cost 8.95 for both lamps. Now when I hit the brakes I have a full 20 watts blairing at you.
Tom | | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | Speedway has the LED taillights in the OEM style housings for the 47-53 trucks for only $30 each, which is what I paid for a non-turnsignals set from CD with incandensent bulbs! They've also got led taillights for many different older cars/trucks.
| | | | | Joined: Jun 2001 Posts: 793 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 793 | I got a pair of LED lamps from "Chevs of the 40's" and they are flat out awesome. My truck is 12 volt. Check 'em out! http://community.webshots.com/mypho...mp;albumID=464784588&security=ybPaFK
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver- Sold 9-15-25 1946 Chevy COE - SOLD 1-5-26 BUH BYE CHEVY! 1959 GMC Half ton long bed NAPCO | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Mine came from Technostalgia as a retrofit kit into the original taillamps. Much brighter than incandecents and they won't burn out. I'm running APC amber led 1157 type bulbs in the front too, keeps the clear lens with amber illumination. Just make sure to put in an electronic flasher or your signals may not work properly.
Bill Burmeister | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | If some one wants the hi intensity 1057 bulbs I bought from speedway (a good firm) cost me about $10 I would be glad to send them for the postage and a pair of regular bulbs. They were better but not by much. | | | | | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 | what is the link to Speedway?
Blue 50
1950 3100 w/57 235 Patrick’s Saginaw 4 speed and 3:55 rear end | | | | | Joined: Oct 2004 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 47 | The site at
superbrightleds.com
has some good info. They also sell the proper load resistors so that your stock flashers and stuff should still work with the LED replacements.
Good luck.
-Joel
'52 3800 Panel School bus conversion... Glass all around. (check the gallery!)
outside of a dog, a book is a man's best freind. inside of a dog it's too dark to read. -Groucho Marx
