6 members (Rusted Nut, FAST55, KEVINSKI, Wally / Montana, HandyAndy, 1955 1 Series), 47 guests, and 3 robots.
Topics128,090
Posts1,056,018
Members48,430
#207119 05/03/2006 6:21 PM
OK...I've searched the archives and haven't really come up with an answer so here goes...
I have a leak in my brakes so I'm going to replace the MC, all wheel cylinders, and all lines. I am not trying to upgrade to power brakes, just make what I have good and reliable. Here's the twist...after reading through the archives I get the impression that a dual MC is a good idea. If I put the dual MC in do I need a prop valve? Wheel cylinders on the front are 1 1/8" bore, and rears are 1" bore.
Daily Driver 63 C-10 LWB Fleetside
#207120 05/03/2006 6:47 PM
i dont see any reason you would need a prop valve. the original m/c worked front and back with same pressure so why wouldnt a dual?
#207121 05/03/2006 8:17 PM
I agree, but I've read some differing opinions
#207122 05/04/2006 12:24 AM
You would only need a prop valve if you were to install disc brakes up front, due to the increased stopping power of disc brakes. It would balance the braking power out to what you have now. So, I say no prop valve on a drum/drum set-up,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#207123 05/04/2006 1:06 AM
Hi,I would use a Wildwood brand prop... valve.It has a knob to "dial in" the right amount of brake to the rear.This will prevent that rear wheel lock up that happens many times with a lightly loaded pick up and good brakes.They are not that costly.The newer trucks have the lever type that increases the brakes to the rear as you add weight.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
