0 members (), 170 guests, and 3 robots.
Topics128,081
Posts1,056,078
Members48,434
#207110 05/03/2006 6:20 PM
With my ongoing radial tires/versus stock rim size battle I have found some aftermarket steelies from a well known company that are 16 x 6". They will not take my stock hub cap but they are brand new, welded rims with a safety bead. My question is about the 6" rim width and how, if any ill effect, it would have on my stock spindles and rear axle? The tires would be 215-85R16.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
I can't imagine they would be an issue.
Bill, I'm NEEDING rims like those, can you tell me where you found them and have you checked the offset to make SURE they'll bolt up and actually turn on your old truck? Oh, I need 8 holer's, is that what you are talking about? Any help will be appreciated, thanks, randy
#207113 05/04/2006 11:23 PM
Randy these came from Wheel Vintiques but they are 6 bolters. I have not checked offset, asking for a normal wheel.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#207114 05/05/2006 12:49 AM
Socket Breaker
Socket Breaker
Wheel Vintiques is listed and linked:
http://woogeroo.home.mindspring.com/autolinks/wheels.html
Stockton Wheel has some 3/4 ton wheels.
-W
Randy you raise a good point about these wheels actually fitting even though they are 16" with the right lug hole pattern. Until I actually get to try one I won't know if they do have the right offset or backspacing. I guess I could measure the backspacing on one of my stock wheels and see if it is the same on the aftermarket one. I just thought I would order a set with standard offset. Anybody have any better ideas or advice?
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Bill,
I believe Stockton Wheel could weld later model rims on your existing wheels and solve your problem. That is what I did on my truck in order to have disc brakes and keep my stock wheels and hubcaps, because I ran into the offset issue with my stock rims and not enough clearance for the caliper.
I know mine are 15"s not 16", but I would think they would have a 16" rim that would work with your existing wheel. It would be worth a phone call.
Jim Karras
Orange, CA
'59 Chevy Apache 32 Stepside Pickup
E-mail: [email protected]
Internet: www.59apache.com
Thanks Jim. They can do all that and I have spoken to them. They are on my list of 'potentials'.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Thanks Jim. They can do all that and I have spoken to them. They are on my list of 'potentials'. What I am wondering now is about offset and back spacing. I think if the wheels are widened on the inside the tires may rub the tie rod ends. I can get the wheels I want but they have to be ordered and if they don't work I am stuck with them. The price up here would work out to about $500 for the wheels including taxes. That is okay if they fit but out of my budget if they don't.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
