1 members (SandraD), 56 guests, and 5 robots.
Topics128,021
Posts1,055,355
Members48,420
#206591 04/26/2006 11:53 PM
ok talking about a 305sbc. my th350 needs vacuum as does my power brake booster. i am only aware of 2 ports to get vacuum from. 1 is the carb base. I was told this was varible and i dont want to use this for my power booster. the other port is behind the carb on the manifold between the distributer and carb. the rear port is hooked into my th350.
what is the proper way to hook both the transmission and the booster up and which ports? should i t off the rear port for both?
thanks in advance
#206592 04/27/2006 2:48 AM
What kind of carb do you have?
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#206593 04/27/2006 6:47 AM
You should check the vacuum from both sources-
One is the manifold and the other is the carb. One is ported and the other isn't. For the Booster you'll probably want it from the manifold directly. If there is something else connected using a Tee, that shouldn't be a problem.
Whereever you get the vacuum to the booster from don't forget to put a filter in the line to prevent unburned fuel and crankcase gases from getting to the booster 'cause they'll ruin the diaphragm.
Autozone has those filters in their HELP product line with the other red blister pack things. Napa has them too.
#206594 04/27/2006 4:16 PM
sounds good thanks nm51. so what part of burque you in? i have spent many years there. used to live over off Kathrine and Georgia and graduated from Highland HS
#206595 04/27/2006 6:36 PM
I live behind the Quarter's on Yale and Cesar Chavez, which used to be called 'Stadium.' Right next to 'The Pit', Isotopes Field (f/k/a the Dukes) and the football stadium. I know right where Katherine and Georgia is-
#206596 04/27/2006 11:10 PM
oh i know where you are at. used to be all mesa around there... guess its grown up a bit huh? alb is beautiful and i would like to live there again someday but to tell you the truth i feel safer in dallas! the gangs and violence have gotten out of hand. then again i didnt live in the best part of town either!
