0 members (),
51
7
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | ok talking about a 305sbc. my th350 needs vacuum as does my power brake booster. i am only aware of 2 ports to get vacuum from. 1 is the carb base. I was told this was varible and i dont want to use this for my power booster. the other port is behind the carb on the manifold between the distributer and carb. the rear port is hooked into my th350.
what is the proper way to hook both the transmission and the booster up and which ports? should i t off the rear port for both?
thanks in advance | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | What kind of carb do you have? Scott | | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | You should check the vacuum from both sources-
One is the manifold and the other is the carb. One is ported and the other isn't. For the Booster you'll probably want it from the manifold directly. If there is something else connected using a Tee, that shouldn't be a problem.
Whereever you get the vacuum to the booster from don't forget to put a filter in the line to prevent unburned fuel and crankcase gases from getting to the booster 'cause they'll ruin the diaphragm.
Autozone has those filters in their HELP product line with the other red blister pack things. Napa has them too.
| | | | | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | sounds good thanks nm51. so what part of burque you in? i have spent many years there. used to live over off Kathrine and Georgia and graduated from Highland HS | | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | I live behind the Quarter's on Yale and Cesar Chavez, which used to be called 'Stadium.' Right next to 'The Pit', Isotopes Field (f/k/a the Dukes) and the football stadium. I know right where Katherine and Georgia is-
| | | | | Joined: Jul 2005 Posts: 227 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 227 | oh i know where you are at. used to be all mesa around there... guess its grown up a bit huh? alb is beautiful and i would like to live there again someday but to tell you the truth i feel safer in dallas! the gangs and violence have gotten out of hand. then again i didnt live in the best part of town either! | | |
