0 members (), 132 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#205413 04/04/2006 1:31 PM
What can you guys tell me about replacing the rope main seal with a neoprene seal? Will the standard seal in a gasket set fit the 1955-58 small blocks?
#205414 04/04/2006 6:45 PM
Oh come on guys! I thought I'd get all my answers here.
#205415 04/04/2006 7:03 PM
books state the neoprene seal won't fit the rope blocks properly, but whada they know? grin some folks say they do it and it works - I've always used the rope in blocks meant for that, and had good luck
#205416 04/05/2006 12:36 AM
Use rope where rope came out as Red58 stated,unless the block/cap has been cut for neoprene.My friend had a Crosley truck and couldn't get a rear main seal.Had the block machined to fit a one piece aircraft seal(propshaft seal).Cost big bucks but it sure looked nice.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#205417 04/05/2006 1:29 AM
They make a neoprene seal as a replacement for the rope. At least they did when I replaced the rear main seal on my father in-laws 55 Ford Customline. Unless the engine is out and the crank is out, you may then have a 50% chance of getting a rope to seal. good luck,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#205418 04/05/2006 1:30 PM
Most of the common repairs such as main seal replacement have been discussed numerous times and a lot of the repairs are in the tech tips section.. use the search function.
Another quality post.
Real Trucks Rattle
#205419 04/05/2006 4:40 PM
Oly Offline
builder, go here Tech tip and use the rope or wick type seal. It is cheap and works better. Try to get the old wick type seal if possible. Don't soak it as some have tried before the install (it will swell on ya and won't fit).
Oly in Oregon
Rest in Peace
1945 GMC COE Victory Truck
1953 Willys CJ3B
1955 Chevy 1st series 3/4-ton
1958 WIFE Last series
Never say "Whoa" in a mud hole
#205420 04/05/2006 5:52 PM
Oly, is this tech tip true for the sb v8 also?
"All right, they're on our left, they're on our right, they're in front of
us, they're behind us...they can't get away this time"
Lt Gen. Lewis B."Chesty" Puller, USMC
#205421 04/05/2006 6:05 PM
rope seals work fine if installed correctly..neoprene seals work also,,have installed them where a rope was removed and had no problems....doc
#205422 04/14/2006 3:06 PM
OK, Heres the dope as I have found out. The 1955-1958 small block chevy 265-283 cubic inch motor uses a rope seal. We all new that. The main seal in the later model gasket kits will not even fit. I ordered a seal from Ecklers ($30 something each)that was a rope seal replacement. It comes with a wire that is inserted next to the seal to keep it in its correct position. I don't see a problem with this design, but then again I haven't run the engine yet.
When I went to the local parts store, they said they could get one for my engine for $11. When I went to pick it up the package said 1959-1967. It would not fit the early sbc. I had the attending counter computer parts looker upper check out the earlier engines for the same part number. They either had a rope seal or the late model neoprene seal. The years in their computer gave the late model seal number for the 1957s too. So I guess in answer to my own questions are;
1. No, the standard seal in the sbc gasket kits will not fit the early years.
2. The standard gasket kits do not come with a rope seal, and the after market neoprene seal is quite expensive.
3. If the parts guy can read a computer but cannot read a book, your chances of successful cross referencing are slimmer still.
#205423 04/14/2006 3:24 PM
4. if the parts guy looks much younger than 50, find a different parts place grin
