| | | Forums66 Topics128,042 Posts1,055,518 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | What can you guys tell me about replacing the rope main seal with a neoprene seal? Will the standard seal in a gasket set fit the 1955-58 small blocks? | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Oh come on guys! I thought I'd get all my answers here. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | books state the neoprene seal won't fit the rope blocks properly, but whada they know?  some folks say they do it and it works - I've always used the rope in blocks meant for that, and had good luck Bill | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Use rope where rope came out as Red58 stated,unless the block/cap has been cut for neoprene.My friend had a Crosley truck and couldn't get a rear main seal.Had the block machined to fit a one piece aircraft seal(propshaft seal).Cost big bucks but it sure looked nice.
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | They make a neoprene seal as a replacement for the rope. At least they did when I replaced the rear main seal on my father in-laws 55 Ford Customline. Unless the engine is out and the crank is out, you may then have a 50% chance of getting a rope to seal. good luck, Scott | | | | | Joined: Dec 2002 Posts: 3,439 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,439 | Most of the common repairs such as main seal replacement have been discussed numerous times and a lot of the repairs are in the tech tips section.. use the search function.
| | | | | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | builder, go here Tech tip and use the rope or wick type seal. It is cheap and works better. Try to get the old wick type seal if possible. Don't soak it as some have tried before the install (it will swell on ya and won't fit).
Oly in Oregon Rest in Peace1945 GMC COE Victory Truck 1953 Willys CJ3B 1955 Chevy 1st series 3/4-ton 1958 WIFE Last series Never say "Whoa" in a mud hole
| | | | | Joined: Jun 2003 Posts: 156 Shop Shark | | Shop Shark Joined: Jun 2003 Posts: 156 | Oly, is this tech tip true for the sb v8 also?
"All right, they're on our left, they're on our right, they're in front of us, they're behind us...they can't get away this time"
Lt Gen. Lewis B."Chesty" Puller, USMC | | | | | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | rope seals work fine if installed correctly..neoprene seals work also,,have installed them where a rope was removed and had no problems....doc | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | OK, Heres the dope as I have found out. The 1955-1958 small block chevy 265-283 cubic inch motor uses a rope seal. We all new that. The main seal in the later model gasket kits will not even fit. I ordered a seal from Ecklers ($30 something each)that was a rope seal replacement. It comes with a wire that is inserted next to the seal to keep it in its correct position. I don't see a problem with this design, but then again I haven't run the engine yet. When I went to the local parts store, they said they could get one for my engine for $11. When I went to pick it up the package said 1959-1967. It would not fit the early sbc. I had the attending counter computer parts looker upper check out the earlier engines for the same part number. They either had a rope seal or the late model neoprene seal. The years in their computer gave the late model seal number for the 1957s too. So I guess in answer to my own questions are;
1. No, the standard seal in the sbc gasket kits will not fit the early years. 2. The standard gasket kits do not come with a rope seal, and the after market neoprene seal is quite expensive. 3. If the parts guy can read a computer but cannot read a book, your chances of successful cross referencing are slimmer still. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | 4. if the parts guy looks much younger than 50, find a different parts place Bill | | |
