Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (jay d, NJC, baldeagle, Wayne67vert, Joe W), 50 guests, and 2 robots.
Topics128,005
Posts1,055,254
Members48,418
#202820 03/04/2006 1:12 AM
Junior Member
Junior Member
Alright the truck i'm getting noone can seem to find the key so how hard is it to get the ignition switch out so i can get one with a key to start the bad boy....btw its a 66...Terry
#202821 03/04/2006 1:27 AM
Pretty easy. You just unhook the wires on the back of the ignition lock, and take it out. Then you slide the new one in and reattatch the wires. Nothing is ever as easy as it sounds, but this is a pretty straight forward job. Good luck.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
#202822 03/04/2006 1:36 AM
Junior Member
Junior Member
I'm having the same issue with my '67 GM truck. My ignition is on the dash and I can't seem to remove it. I've tried holding the front part while turning the back by hand, but it only goes so far...I'm stuck.
#202823 03/04/2006 2:06 AM
Rick, the actual switch part under the dash has a bit of a tooth that fits in a little notch to keep it from turning while you unscrew the face bezel all the way off - in other words, hold the back, turn the front!
#202824 03/04/2006 1:42 PM
Usually the lock cylinder has to be removed first to unscrew the bezel to remove the switch. The key is needed to remove the lock cylinder. Destructive techniques abound if you are planning on replacing it all. A Dremel with a cutoff wheel or burr to split the bezel keeps the dash undamaged.
Saving it all? Try a locksmith.
#202825 03/04/2006 6:59 PM
Junior Member
Junior Member
thanks guys i think i will try and mess with because i really don't want to tear the dash up just to get it out..Terry.
#202826 03/04/2006 8:09 PM
Riding in the Passing Lane
Did you try turning it. Sometimes these old switches are wore out & will turn with any key or a screwdriver.
1972 Chevy c10 Cheyenne Super
#202827 03/05/2006 1:44 AM
Junior Member
Junior Member
thanks everyone...i just got the title tonight and i got lucky and he said he found the key for it,so it was a good day....but thanks to ever for giving me some help....Terry
#202828 03/05/2006 2:00 AM
I bought a 63 without a key and the doors were locked too. I put the key from my 64 in and worked and wiggled and it unlocked the door. The ignition was sloppy enough that it worked just like it belonged. I can start my 64 with a screwdriver or any other key that will fit into the slot. Anti-theft precautions wasn't high priority back then I guess,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#202829 03/05/2006 9:36 PM
Now that you have the key there is one thing that I did not see mentioned. Put the key in the slot. Put the end of a paper clip in that pin hole, that is off to the side. Turn the key to the left and the tumbler should pull out easily.
'67 GMC 3/4 292 4spd
