3 members (Cosmo, Wayne67vert, Bills Auto Works), 60 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#202332 02/27/2006 7:01 AM
... well, *I* need a hook.. actually TWO hooks.. to go on the ends of my tailgate chains!
Local lumber/hardware outfits don't seem to have them.. anyone know of a good source for just the hooks?
I saw that the 'usual suspects' carry the whole chain with a hook.. but I already have the chains.. just need the hooks.
I got S hooks and carabiner style ones at the local hardware store to use on my 47 jeep which uses the same set up. I then removed links on the chains until the tailgate was level and then I added some pipe insulators so the chains wouldn't bang on paint. Came out rather nice.
#202334 03/09/2006 11:29 PM
Heat and bend some round stock if you need a diferant size. But larger harware stores ave many diferant size 's' hooks.
"It ain't a truck if you can't hose out the cab."
#202335 03/09/2006 11:35 PM
and ten speed bike tubes are a perfect size for the chain covers grin
#202336 03/10/2006 12:52 AM
I like that idea Bill! I imagine that because the rubber is more pliable it bends easier so the chains hang more normal - unlike the stiffer covers you can buy that make the chains hang very awkwardly... would I be right??
Larry Bear
55.5 Chevy 3100 Panel
I (as bill suggested) also use inner-tubes & put a small black zip-tie thru my bicycle tube and chain link to keep the tube from slidding/ dropping down when i have unhooked the hook
Jim & Caroline
I have a complete set you can have Free to a good home. e mail me
#202339 03/11/2006 12:56 AM
I use bike inner tubes on the chains on my 48 Cj2A, but I found you need a small hole at the lowest point when the tailgate is closed. Rainwater collected and rusted my chains pretty bad.
Rob H.
