8 members (Rusty Rod, TUTS 59, Peggy M, 3B, J Lucas, David Bush, Southerntruck, 1 invisible),
103
Mod | | | Forums66 Topics128,065 Posts1,055,863 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | ... well, *I* need a hook.. actually TWO hooks.. to go on the ends of my tailgate chains!
Local lumber/hardware outfits don't seem to have them.. anyone know of a good source for just the hooks?
I saw that the 'usual suspects' carry the whole chain with a hook.. but I already have the chains.. just need the hooks.
| | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | I got S hooks and carabiner style ones at the local hardware store to use on my 47 jeep which uses the same set up. I then removed links on the chains until the tailgate was level and then I added some pipe insulators so the chains wouldn't bang on paint. Came out rather nice. | | | | | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | Heat and bend some round stock if you need a diferant size. But larger harware stores ave many diferant size 's' hooks.
"It ain't a truck if you can't hose out the cab."
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | and ten speed bike tubes are a perfect size for the chain covers Bill | | | | | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | I like that idea Bill! I imagine that because the rubber is more pliable it bends easier so the chains hang more normal - unlike the stiffer covers you can buy that make the chains hang very awkwardly... would I be right?? | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | I (as bill suggested) also use inner-tubes & put a small black zip-tie thru my bicycle tube and chain link to keep the tube from slidding/ dropping down when i have unhooked the hook
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | I have a complete set you can have Free to a good home. e mail me | | | | | Joined: Sep 2005 Posts: 191 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 191 | I use bike inner tubes on the chains on my 48 Cj2A, but I found you need a small hole at the lowest point when the tailgate is closed. Rainwater collected and rusted my chains pretty bad.
Rob H. | | |
