2 members (55shaker, Paul_WNC), 75 guests, and 1 robot.
Topics128,035
Posts1,055,552
#201355 02/17/2006 6:06 PM
hey yall!does a 5-speed tranny from an s-ten fit a 283 -without any special kit? or do i put in a 700 r4?...just curious.because that is my back up motor. i plan on using 6 w/3 on the tree.and as original as possible.
#201356 02/17/2006 6:42 PM
The S-10 T-5(not on the tree) doesn't care what motor is out front, just as long as you have a Chevy bellhousing. You need to read all the tips re this trans on this site, you may have to shorten the input shaft and front bearing retainer. 700r4 should bolt up to your V8 and 230/250/292 six, but not the old 235 six, but there are adaptors for just about everything.
1946 1/2-Ton Chevy
#201357 02/17/2006 7:00 PM
thax a bunch ,,,will half to spend a litle more time on the box instead of the shop.
#201358 02/17/2006 8:50 PM
Socket Breaker
Socket Breaker
chevytrucks.org - also has some info on t5's in their technical area.
-W
