1 members (Rusty Heaps),
116
0
Mod | | | Forums66 Topics128,035 Posts1,055,564 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 192 Member | | Member Joined: Jan 2005 Posts: 192 | hey yall!does a 5-speed tranny from an s-ten fit a 283 -without any special kit? or do i put in a 700 r4?...just curious.because that is my back up motor. i plan on using 6 w/3 on the tree.and as original as possible. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | The S-10 T-5(not on the tree) doesn't care what motor is out front, just as long as you have a Chevy bellhousing. You need to read all the tips re this trans on this site, you may have to shorten the input shaft and front bearing retainer. 700r4 should bolt up to your V8 and 230/250/292 six, but not the old 235 six, but there are adaptors for just about everything. | | | | | Joined: Jan 2005 Posts: 192 Member | | Member Joined: Jan 2005 Posts: 192 | thax a bunch ,,,will half to spend a litle more time on the box instead of the shop. | | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | chevytrucks.org - also has some info on t5's in their technical area.
-W | | |
