| | | Forums66 Topics128,107 Posts1,056,225 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Check it out.. Old truck Now the guy who owns it thinks its a 39.. but i'm guessing its gotta be older than that because it has a one piece windshield. The Mfg tag is pretty hard to make out.. looked like 31TD08.. but that dosent work in the VIN cruncher.. my guess is somebody who knows grills would know. Check out the sweet [censored] US army crane in the background!
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | | | | | | Joined: Jan 2005 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 63 | I second that. It's a 38'
1941 AK named "PETEY" my buddy.
| | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Thats what I was thinking.. but didnt know enough about a '37 to eliminate that.
Thanks for the help, guys!
| | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Geez Fumblin...you are on a roll! How about the crane in the back ground...you need that in your yard, don't you?
Man you have been finding a lot of stuff this winter...send some up my way! | | | | | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | Fumblin,
37's and 38's are both one year only models, in both the cars and the trucks. They are amongst the easiest models to identify, once you see them or if you know what the grill in the cars of those same years look like.
There can be no mistaking the trucks, as they're just larger versions of the same year car grills.
The 37 is similiar in shape to the 38, but the bars run vertically instead of horizontally, and have a little bit of a sharper point in the front. | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Believe it or not, this one starts, runs, and drives.. tires are a little on the shot side, tho.
| | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Dude wants $500 bones for it.. no title. I'd guess it'll keep on sitting there!
The crane he's asking $3500 for.. the motor in the crane part somebody swapped out with a caterpillar one.. it's pretty cool.. but not anything I need.
| | | | | Joined: Nov 2005 Posts: 355 Member | | Member Joined: Nov 2005 Posts: 355 | Fumblin, couldn't you use that crane to throw hay to the moo's? You could even put a big claw on it and stack the hay with it. | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | Is the bar across the top of the windsheild to join wipers? My 38 just has one on the drivers side | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | I didnt really look at it all that close.. i just assumed there was only one wiper motor, and that bar was used to make the other blade move.
The crane has a big ole claw bucket on it.. but I don't have nearly that many moos to feed to use a deal like that.
| | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | Fumblin, Is that a pickup, or a big bolt? | | | | | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | The TD is a 1938 1.5-ton dually with a 157" wheelbase.
Fumblin: That serial number should work in the cruncher. Try using 21 in place of 31 for the factory code.
Curt ---- 1953 Chevy 6400, 1957 Chevy 2dr Sedan --"Mediocrity is easy, the good things take time"
| | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Xram53 beat me to it! It had dullies, so my guess was going to be that it was bigger than a 'pickup'.. but you know, the older big bolt trucks sure don't LOOK all that big. I'll bet if a fellow were to drop a '41 thru 46 era bed on the back, and swap out the rear axl, most folks wouldn't be able to tell it wasnt a pickup. If the cat had have had a title, I might have seriously thought about the $500.. but his story is the folks he bought it from were supposed to get him a title and never did.. and now they're out of the country. On a quasi-related note.. I found the guy who bought the '42 1/2 ton I 'spotted' a week or so ago.. the wife was in a rare mood, and wanted to go 'stovebolt spotting' with me yesterday afternoon. As we were driving past a small garage that always has old trucks sitting out front (i always assumed he was a collector like me, so never bothered to stop) I saw that truck in his 'collection'. He was a pretty nice guy, and we swapped whats left of my '39 cab for four nice rims and tires. He sold me a fan for $5 that I needed, and the torque tube u-joint out of a '39 or '40 1/2 ton that I was hoping would have fit my '46... but it didnt.
| | | | | Joined: Aug 2005 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 73 | The 1 1/2ton 38 has a much heavier drivetrain then a pick up, with 20" wheels.They also have bigger fenders so those big tires will fit.I'm pretty sure the cab,doors,hood and grille are the same as a pick up . | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | you could get a bonded title with a bill of sale. its a bit of a pain in the butt, but I have done it a few time with old motorcycles. | | |
