2 members (walter74, WICruiser), 77 guests, and 1 robot.
Topics128,115
Posts1,056,624
Members48,450
I hope firstly that I am not flogging a dead horse on this. Secondly I hope that im not making this more complicated than it really is.
ok. i have a 63 c10. the front brakes are stock manual. I have all components from a 71 c10. spindles, calipers, rotors, hubs, booster, m/c and prop valve.
This is my plan:
I want to get new drop spindles and new calipers. i want to go with 73 for these parts because suspension and steering parts are cheaper.
my questions:
1. what ball joints will mate the 73 spindles to my 63 control arms?
2. can I use my 71 rotors with 73 spindles and 73 calipers?
3. any info or advice on mounting the 71 booster/mc/prop valve setup in my 63?
4. can I use my existing brake lines or will I need to bend new ones?
Thanks in avance and sorry if im sounding dumb I just want to wrap my head around this before I start taking things apart.
To answer some of those questions, you can do a few quick things. Try looking up the rotors for a 71 and a 73 truck. If its the same part number from an on-line supplier - then they'll work. You could also try the same thing on ball joings. See if the 63 truck and the 73 truck use the same part. If not, then try going to a parts story that has both and see what the differences are. Autozone.com or another might have pictures of the things on line. That will at least get you started.
I don't think its a question of dead horse, its that people are probably reluctant to give you opinions that could be wrong.
From what I've read, it would be easier to swap out the whole front suspension as an assembly, it's just a matter of drilling a few bolt holes into the frame. Food for thought,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Troy.. look at the 'young guy needs help' discussion. Talk there about swapping the entire '71 front end over to get disks and keep the 6 lug wheels.
Attitude - The difference between an adventure and an ordeal!
Deja Moo - The feeling you've heard this bull**** before!
'63 Chev Fleetside Longbox 'Rusto-rod' 'Big Red'
'69 or'70 or ? Mantaray DuneBuggy
Troy, ya might try this web site to get more insight on your swap. lots of good tech info
www.nolimit.net
www.classicperform.com
keep on trukin'
resto44
Junior Member
Junior Member
a mechanic i know here in town got his disc setup from a '78 van. he used the spindles, calipers, rotors and used the upper ball joints for a '78 chevy on his existing upper control arms. he said the lowers could stay the same. he also used the power steering from that van and used the steering components fron the van also. he said he had to drill a couple holes; i think for the idler arm. his name is john and he works at richard and 'da boys in lewisville. i believe they're in the book.
