1 members (RLB), 215 guests, and 2 robots.
Topics128,094
Posts1,056,066
Members48,433
#199185 01/25/2006 3:45 AM
V
V Offline
Hello all, this is my first post of many to come.
I am a new owner of my Grandfathers 66 c10 lwb stepside. 250 six 3 on the tree one wheel wonder. In fact it's a wonder its still attached to the frame but that is for another post.
Right now it's cold here in Seymour, TN and the old truck hasn't had a heater in it since the Carter admin. I have looked at many suppliers and they all have the deluxe listed. Chevy duty lists one core for both heaters and LMC list 3 different cores and heaters. Question is will a deluxe core fit a thrift air box or not? Any help or thoughts appreciated.
1966 C10 250/3 Stepside
1966 C10 327/3 Fleetside
1972 Buick Centurion 455/TH400
1964 Plymouth Valiant 360/A833 4spd
1964 Plymouth Sport Fury 440/727
I've got a new car....It was made in '72
welcome to the garage Valiant! we're gonna wanna be seein some pictures of grandad's ol workhorse sometime - but meanwhile we'll still try to help where possible
the various 'grades' of heaters these ol trucks have are frequently configured different enuff that they've got different shaped cores, so what I'd suggest is to take yer original core to a rad shop and see if they can make you a new one - that's usually do-able, as if the tanks aren't totally rotten they can get a variety of size cores and rebuild it - cheaper than the repro guys - failing that, measure yours up carefully and note the position of the inlet and outlet, and talk to someone like LMC who has a variety, one of which might be the same
Valiantsignet200,
A big welcome to the Stovebolt. I have used Radiator Express before and they were extremely customer focused. Just for grins, I did a search for your heater core on there site. They have two different styles listed.
Take a peek...the price looks great and the explanation might clear up your questions about the different types of cores.
http://www.radiatorexpress.com/part_lookup.asp
Stuart
Measure it up and call Carquest or NAPA and tell them which one you have. That's all I had to do for my 64.
Good luck,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
I replaced my heater core in my '66 C-10 a few years ago, and the deluxe heater core did fit with only slight modifications.
I have used A to Z Auto Radiator,Southold,New York with excellent results.They will make a radiator or core if necessary.Give them a call @ 1-631-765-6849 and see what they say.Small shop but great folks to deal with!!
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
V
V Offline
Thanks for the input guys. I'll pull it out of the heaterbox this weekend and see where it takes me.
V
V Offline
Doug 57, Explain slight modifications. The reason I ask is a board member has offered a deluxe core to me. I know that the deluxe core is 2 1/4 longer then the standard. Did you have to cut your box out on the inside? Or is there a simple thingamajig that pops out to allow the deluxe core to fit?
Thanks Again.
#199193 01/27/2006 11:35 PM
If I recall correctly, you only need to drill two new holes. It worked on mine OK, and I have the thrift air heater
