| | | Forums66 Topics128,068 Posts1,055,881 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 30 New Guy | | New Guy Joined: Jan 2006 Posts: 30 | Hello all, this is my first post of many to come.
I am a new owner of my Grandfathers 66 c10 lwb stepside. 250 six 3 on the tree one wheel wonder. In fact it's a wonder its still attached to the frame but that is for another post.
Right now it's cold here in Seymour, TN and the old truck hasn't had a heater in it since the Carter admin. I have looked at many suppliers and they all have the deluxe listed. Chevy duty lists one core for both heaters and LMC list 3 different cores and heaters. Question is will a deluxe core fit a thrift air box or not? Any help or thoughts appreciated.
1966 C10 250/3 Stepside 1966 C10 327/3 Fleetside 1972 Buick Centurion 455/TH400 1964 Plymouth Valiant 360/A833 4spd 1964 Plymouth Sport Fury 440/727 I've got a new car....It was made in '72
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | welcome to the garage Valiant! we're gonna wanna be seein some pictures of grandad's ol workhorse sometime - but meanwhile we'll still try to help where possible
the various 'grades' of heaters these ol trucks have are frequently configured different enuff that they've got different shaped cores, so what I'd suggest is to take yer original core to a rad shop and see if they can make you a new one - that's usually do-able, as if the tanks aren't totally rotten they can get a variety of size cores and rebuild it - cheaper than the repro guys - failing that, measure yours up carefully and note the position of the inlet and outlet, and talk to someone like LMC who has a variety, one of which might be the same
Bill | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Valiantsignet200, A big welcome to the Stovebolt. I have used Radiator Express before and they were extremely customer focused. Just for grins, I did a search for your heater core on there site. They have two different styles listed. Take a peek...the price looks great and the explanation might clear up your questions about the different types of cores. http://www.radiatorexpress.com/part_lookup.asp Stuart | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Measure it up and call Carquest or NAPA and tell them which one you have. That's all I had to do for my 64. Good luck, Scott | | | | | Joined: Apr 2005 Posts: 313 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 313 | I replaced my heater core in my '66 C-10 a few years ago, and the deluxe heater core did fit with only slight modifications. | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | I have used A to Z Auto Radiator,Southold,New York with excellent results.They will make a radiator or core if necessary.Give them a call @ 1-631-765-6849 and see what they say.Small shop but great folks to deal with!!
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Jan 2006 Posts: 30 New Guy | | New Guy Joined: Jan 2006 Posts: 30 | Thanks for the input guys. I'll pull it out of the heaterbox this weekend and see where it takes me.
| | | | | Joined: Jan 2006 Posts: 30 New Guy | | New Guy Joined: Jan 2006 Posts: 30 | Doug 57, Explain slight modifications. The reason I ask is a board member has offered a deluxe core to me. I know that the deluxe core is 2 1/4 longer then the standard. Did you have to cut your box out on the inside? Or is there a simple thingamajig that pops out to allow the deluxe core to fit? Thanks Again.
| | | | | Joined: Apr 2005 Posts: 313 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 313 | If I recall correctly, you only need to drill two new holes. It worked on mine OK, and I have the thrift air heater | | |
